SolaraGuy.com • View topic - Engine Misfiring Changed plugs, swapped coils & wires
Postby hang3xc » Wed Jan 20, 2010 7:54 pm
I got P0303 and figured I'd have a mechanic do it, till I found out they wanted $400 to change plugs & wires. I went home and changed the plugs. They were in fairly poor shape.. Still got P0303
Next I swapped the coil packs to see if the cylinder misfire would jump to another cylinder, but it didn't, so I assume coil packs are good
Next I swapped the plug wires, but that didn't change the misfire to another cylinder either, so I assume those are also OK
I'm guessing maybe I have a slightly clogged fuel injector? The car doesn't really run bad, it just a little rough. I don't think it's a fuel delivery problem because it rides fine on the highway when fuel demand is high.
Does the #3 injector seem like the likely culprit? How much does it typically cost to have them cleaned, or do they replace the clogged one? I'm guessing this is going to get expensive. Are there any chain stores that do a good job with this?
Is there anything else it might be?
Thanks for any help
Ron
hang3xc
Postby Dawgz » Wed Jan 20, 2010 8:00 pm
u could switch your injectors.....
google "witch hunter", they are a good injector cleaning service.
ur issue does sound like an injector issue from all the troubleshooting you have done.
Postby 1gSE » Wed Jan 20, 2010 8:10 pm
you wouldn't happen to have a remote starter that was installed sh*tty like i did would ya? I say swap injectors around. Doesn't take long at all
Solara-M62 @ 5.5psi
1gSE
Postby jetbtkng » Thu Jan 21, 2010 1:48 am
when was the last time you used fuel injector cleaner............. :drinking:
