SolaraGuy.com • View topic - Fog bubl replacement
Postby lildk50 » Sun Aug 03, 2003 8:06 pm
I jus got some 9006 bulbs for my 2000 solara fogs...i was jus wonderin if anyone knew a way to actually GET to my fogs. Someone told me i hadda remove my bumper, is that tru? :o if someone knows a better way plz tell me. Or at least an easier. And once I get to my fog assembly, is it jus like switching out the headlight bulbs? :snipersmile:
lildk50
Postby Yanks0114 » Sun Aug 03, 2003 8:24 pm
PLEASE DO NOT POST REQUESTS IN THE DO IT YOURSELF SECTION IT IS FOR TUTORIALS.
Also try searching, we've gone over it before
Re: Fog bubl replacement
Postby FLASH » Sun Aug 03, 2003 8:29 pm
lildk50 wrote:Someone told me i hadda remove my bumper, is that tru? :o
No.
lildk50 wrote:if someone knows a better way plz tell me.
Go under the car and unscrew the screws that hold the cover thats underneath the whole car and move that big black plastic cover out of the way. Now reach in where the fogs are and remove the bulbs and replace them.
lildk50 wrote:And once I get to my fog assembly, is it jus like switching out the headlight bulbs?
For the most part, yes.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby TadS » Sun Aug 03, 2003 8:32 pm
Thanks Yanks, People can't seem to read the this is for tutorials only thing.
Anyway, You don't have to remove the bumper cover to get to the fog laps. If you get under the front of your car you will see that there are plastic panels that are directly under the fog lamps. To change the bulbs you simply drop these panels and twist the bulbs out. It's somewhat time consuming, but it is easy. Hope this helps.
Hey, Flash must be a faster typer than me BWHAHAHAHA!
TadS
