SolaraGuy.com • View topic - speed calibration?
speed calibration?
speed calibration?
Postby 02slera » Fri Jan 22, 2010 1:39 pm
Does anyone know how to adjust the calibration of the speedometer on the 02 solara v6? I was hoping i could get a hypertech programmer and adjust the wheel size in the ecu but apparently they do not make one for the solara. any ideas?
2002 Solara SLE v6
02slera
Postby 02slera » Fri Jan 22, 2010 2:17 pm
further research... im now looking at the Truspeed by superlift, it looks like it may just work but its really for trucks with aftermarket wheels, anyone on here a mechanic? know if the truspeed calibration made for toyota pickups and 4runners and tacomas will work with the A541E transmissions speed sensor?
2002 Solara SLE v6
02slera
Postby TMMK Toy » Sun Feb 14, 2010 11:49 pm
I've been curious about this myself. Not necessarily this specific program but any way to recalibrate the speedo. My tire size is off slightly now and it's actually making my odometer roll over slightly faster than actual milage traveled. I went from a 205/65R15 to a 215/60R15
TMMK Toy
Postby jetbtkng » Sun Feb 14, 2010 11:57 pm
just get another car to drive next to you, & have them go 20, what ever your speedo says, so if it says 22, then your 2 miles an hour over, so 50 would be 52, problem solved.............. :drinking:
Postby TMMK Toy » Mon Feb 15, 2010 12:09 am
You don't get it. It's throwing my odometer off and I want that to remain accurate. I already can figure out how fast I'm going.
TMMK Toy
Postby jetbtkng » Mon Feb 15, 2010 12:13 am
oh, never mind, lol............... :drinking:
Postby trentmeyer23 » Mon Feb 15, 2010 3:51 am
trentmeyer23
Postby 02slera » Mon Feb 15, 2010 5:35 pm
truspeed by superlift ( http://www.superlift.com/accessories/truspeed.asp )
this unit is made for toyota trucks; when installed on solara, it was inconsistent from when you first start driving to 20 minutes later, however directions were not followed on install so results may be wrong as instead of hooking up to wire at transmission, wire behind gauge cluster was used, also wires for signal and 12v supply were bundled together and i believe they are supposed to be separated.
I could get this thing perfectly accurate, let the car sit over night and the next moring it would be -10 mph off at 35mph (gauge says 35 when doin 45). But after driving the car for over 20 minutes this would slowly change and get closer and closer to accurate. biggest problem is even when splicing into the wire directly behind the guages, shift points are changed as well. it seems that the signal hits the gauge and then goes to the computer. when the speedometer reads less than actual speed it will hold gears longer and rev into redline, obviously the opposite happens when the speedometer reads more than actual speed... the shifts come too soon.
I agree it sux that when the speedometer reads higher than actual speed the odometer says your car has more miles then it really does. my car was 4-5mph over actual speed with stock wheels. Readings on car speedometers is not always accurate from the factory.
2002 Solara SLE v6
02slera
Postby bbq bob » Mon Feb 15, 2010 6:00 pm
try jet performance , they have one . not sure if it is for our cars.
bbq bob
Postby JavaJoe_2 » Mon Feb 15, 2010 6:25 pm
jetbtkng wrote:just get another car to drive next to you, & have them go 20, what ever your speedo says, so if it says 22, then your 2 miles an hour over, so 50 would be 52, problem solved.............. :drinking:
Again, old guy math? :roll:
22 at 20 would be 10% off.
So....50 would be 55. :drinking:
Got Boost?? :sweet:
JavaJoe_2
Postby jetbtkng » Mon Feb 15, 2010 6:40 pm
old guys rule, old math, not that new math >>I'm a douche<<.......... :drinking:
Postby trd4life » Mon Feb 15, 2010 6:47 pm
contact Ericsol here on the boards, he can have a custom box made for you. Tell him gabe told you to PM him.
Postby JavaJoe_2 » Mon Feb 15, 2010 6:52 pm
We're not that far apart on age.
Maybe it was because I graduated. 8)
Back on topic...that's why I go with the same size as original.
And the roads really suck here. :(
Got Boost?? :sweet:
JavaJoe_2
Postby jetbtkng » Mon Feb 15, 2010 7:56 pm
you graduated, what school, asshole high, then retard universty, that explains it............ :drinking:
Postby trd4life » Mon Feb 15, 2010 8:44 pm
frank how does the car feel with that yellow front mount on there
