SolaraGuy.com • View topic - HELP with my Toyota Solara Gen 1.5 HIDs
Postby xDeAdDrIp21x » Wed Jan 27, 2010 1:32 am
Hello I'm new to the site.
I installed my O.Nex HID conversion kit to my '02 Solara and turned on my headlights and my HID's didn't turn on. :( I don't know what else to do, then connecting them and trying to turn them on. I heard that i have to disable my daylight lights and have to change a couple fuse's? help would be greatly appreciated.
xDeAdDrIp21x
Postby jetbtkng » Wed Jan 27, 2010 1:36 am
cant help, i dont know who you are, go introduce yourself in introductions,......................... :drinking:
Postby kingkakyle » Wed Jan 27, 2010 2:13 am
u may have it plugged in reverse (so + and - are mixed)
that seemed to be a common problem when first installing
Postby xavier » Wed Jan 27, 2010 7:10 am
Well, I must first suggest that you do hids the right way and retro an OEM projector. I am doing that right now on an 02 solara and Im going to be doing a comprehensive write up.
Second, if you are set on using a pnp kit, check the wires and grounds for any looseness. Check the plugs as well like kingkakyle said.
xavier
Postby TLMNICK » Wed Jan 27, 2010 9:16 am
I'd be willing to bet that the polarity is reversed on the power input on both of those ballasts.
and +1 to introducing yourself.
TLMNICK
Postby xDeAdDrIp21x » Wed Jan 27, 2010 11:23 pm
I finally got them to work, TLMNICK was right the polarity was reversed on both of the ballasts
xDeAdDrIp21x
Postby 1gSE » Thu Jan 28, 2010 8:34 am
Had the same problem when I did mine....now go do a proper intro! Image
Solara-M62 @ 5.5psi
1gSE
