SolaraGuy.com • View topic - Pivot alternator screw
Postby cartang » Thu Jan 28, 2010 10:08 am
I need to get the screw por the alternator /plate SC the car will have timing belt service.
Any place or any of SG member can sell , Thanks in advantage
Camry SC manual
cartang
Postby alltrac92 » Thu Jan 28, 2010 10:14 pm
Good luck finding one and they don't come cheap.
alltrac92
Postby 99BlackSandv6 » Thu Jan 28, 2010 10:28 pm
If you know the dimensions, try: boltdepot.com
If they don't have what you need, try: mcmaster.com
I buy most of my hardware from boltdepot, and the hard
to find stuff I can usually get at mcmaster.
All you need to know is the thread diameter and the length
also the style, which is all visual. If it fits it will work.
The internet is a powerful tool my friend.
Good Luck!!!
Postby trd4life » Thu Jan 28, 2010 11:29 pm
this bolt does not exist in the u.s.
screw
Postby cartang » Fri Jan 29, 2010 7:43 am
Alltrac92 I sent a PM .
cartang
Postby 99BlackSandv6 » Fri Jan 29, 2010 9:48 am
trd4life wrote:this bolt does not exist in the u.s.
That seems unlikely. Do you have a picture of one? I bet I can find a supplier. 8)
Postby krook » Mon Feb 01, 2010 12:49 pm
GOOD LUCK, homie! I said the same thing, and got frustrated after 2 days of searching, emailing price quote requests, before finally finding my own solution.
99BlackSandv6 wrote:If you know the dimensions, try: boltdepot.com
Good Luck!!!
Bolt Depot doesn't have it; i emailed them awhile back--neither does mcmaster.com, which has every other bolt under the sun except our not-found-on-earth 1.25 thread pitch with 10mm x 100mm partially threaded mu'fucka. Oh! and recessed head by the way..! :p
krook
Postby 99BlackSandv6 » Mon Feb 01, 2010 1:27 pm
M10x1.25, 100mm length, partial thread, countersunk? Is it allen head or hex head?
I'm bored so I can look for it. :lol:
I might know a place.
Screw
Postby cartang » Mon Feb 01, 2010 2:17 pm
I think is a Hex I hope it help :)
There is a picture in the post " Pivot bolt replacement , done by Ron
Thanks for help
cartang
Postby trd4life » Mon Feb 01, 2010 2:21 pm
countersunk
39mm of thread roughly
Postby akora12 » Mon Feb 01, 2010 2:59 pm
100mm length
grade 10.9
Postby Dawgz » Mon Feb 01, 2010 3:24 pm
These will be in my hands soon....refer to my thread in the FS section if you are interested.
