SolaraGuy.com • View topic - ECU help with v6 swap
Postby duneman11 » Fri Feb 05, 2010 2:43 pm
as the title states im in the process of doing a i4 to v6 swap. anyway when it came time to hook up the ecu i had gotten for it the top connector doesnt match up. the plug for the ecu is suppose to be a 28p but the one that is on the harness is a 20p. (i think the connector is on the dash harness.) do i have to replace the dash harness to fix this problem? or is there another alternative to fixing it. i still have my i4 ecu if that helps.
p.s. its a 97 camry
duneman11
Postby ASG14 » Fri Feb 05, 2010 7:01 pm
what is the EXACT year, trim, and country of origin of both the donar car and the swap car?
ASG14
Postby duneman11 » Fri Feb 05, 2010 8:38 pm
1997 camry le is the car im swaping the v6 into
i dont have a donor car.
duneman11
Postby trd4life » Fri Feb 05, 2010 9:25 pm
I have the 97 v6 dash harness plug you need at $75 SHIPPED. I had this custom made years ago when i did the exact swap your doing as i wasnt able to find a donor car to get the plug out of in a junk yard. I parted out the car last year and i am pretty sure i still have the plug. You can keep your existing 4cyl dash harness and match up all the pins to the V6 pigtail plug. I was never able to get my a/c to work after doing the swap, as i had a hell of a time trying to figure out how to integrate the V6 A/C amplifier into the harness. I hate wiring.
Postby duneman11 » Wed Feb 10, 2010 8:20 pm
let me know if you still have it.
duneman11
