SolaraGuy.com • View topic - Help if you've used Emanage Ultimate
Postby Mr_Chunkz » Wed Feb 10, 2010 1:11 am
For our 1Mz-FE does anyone know what the inernal switches need to be set to? ( 20 switches total )
- Mr_Chunkz -
The Daily
Mr_Chunkz
Re: Help if you've used Emanage Ultimate
Postby Dawgz » Wed Feb 10, 2010 4:06 am
Mr_Chunkz wrote:For our 1Mz-FE does anyone know what the inernal switches need to be set to? ( 20 switches total )
HKSboost uses it....i think.
Postby Mr_Chunkz » Wed Feb 10, 2010 12:12 pm
I sent him a couple of pms but I'm not sure if he has the info :-?
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby SpeedySolara » Wed Feb 10, 2010 5:47 pm
Is the Emanage Ultimate plug and play? Theres 2 harnesses for the 1MZ-FE designed for the Estima. If you're using the harness, which ECU harness did you use? I apologize I cant answer your question but hope you can answer mine :P
SpeedySolara
Postby Mr_Chunkz » Thu Feb 11, 2010 10:40 am
SpeedySolara wrote:Is the Emanage Ultimate plug and play? Theres 2 harnesses for the 1MZ-FE designed for the Estima. If you're using the harness, which ECU harness did you use? I apologize I cant answer your question but hope you can answer mine :P
I've been told not to use the Estima harness, as not all 1mz harnesses are the same. The emanage is not plug and play in that aspect and you would need to wire it in. Just imagine a Split Second install but slightly more complicated.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby EEngineer » Thu Feb 11, 2010 10:54 am
i have it but i haven't installed it yet.
u should ask tony the tiger
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
