SolaraGuy.com • View topic - Sway Bars
Sway Bars
Sway Bars
Postby hcromeo » Mon Aug 04, 2003 11:41 pm
Since I'm new to the whole upgrading cars and well cars in general (I'm such a newbie), whats up with the sway bars? What do they do? Are they easy to install? Which are the best kind? And how much would they run me?
hcromeo
Postby Fletch_Indiana » Tue Aug 05, 2003 5:47 am
The TRD Rear sway bar is the cheapest and easiest way to go. It runs around $150 and it has 2 settings. Try toyotaparts4u.com or search. I don't think as many people do the front.
Fletch_Indiana
Postby Astro » Tue Aug 05, 2003 7:20 am
Great mod. If you are thinking about the front Whiteline does make one. I have the TRD rear and Whiteline front and they are awesome. When cornering, they keep you car from swaying so much. You know when you are making a hard right and the left side of your car feels like it lifts up, these bars will help keep you even. You can check e-bay, sometimes they have some.
Postby Jai_Jai_Binks » Tue Aug 05, 2003 7:25 am
Question for those of you who do have added the swaybar...how much does that affect the ride quality? I say, cus' when i went 17' rim's i HATED the ride...i've tried three different tires types...from 205, to 225 and currently on 215's....I know as soon as those tires are worn out, i'm going back to stocks! but how does the bar's affect ride quality....
Postby Astro » Tue Aug 05, 2003 7:55 am
The ride is a bit stiff and when going around corners it is tight. I like the fact these sway bars try and keep all 4 wheels on the ground. The struts and springs will affect your ride quality. As far as I can tell the sway bars don't affect it much. To me, you don't get the 'riding on cloud' feeling when going around corners. It's been really worth it. Handleing is much better.
Postby Mole » Tue Aug 05, 2003 8:42 am
jhbhatia wrote:Question for those of you who do have added the swaybar...how much does that affect the ride quality? I say, cus' when i went 17' rim's i HATED the ride...i've tried three different tires types...from 205, to 225 and currently on 215's....I know as soon as those tires are worn out, i'm going back to stocks! but how does the bar's affect ride quality....
the width of the tire has nothing to do with rid comfort. you would have to go to a higher series (ie 215 50 17 instead of 215 45 17)
Postby Jackass-Jeff » Tue Aug 05, 2003 9:28 am
Have you ever ridden in a car w/ 19s, front sb, and coilovers? OUCHIEZ! =x
1GR-FE ftw!
Jackass-Jeff
Postby hcromeo » Tue Aug 05, 2003 10:36 am
Where does the rear sway bar go?
00' Solara SLE V6
2D Black Automatic
Injen Intake
Clear Corners
EL Glow Gauges
rActive Pedals
hcromeo
Postby impactX » Tue Aug 05, 2003 10:36 am
If you don't like to sacrifice the ride quality for performance, you shouldn't modify it in the first place.
Not to mention, stock is definitely NOT a quality ride. It feels like driving a boat more. There's a difference between comfort and driving a boat.
impactX
Postby impactX » Tue Aug 05, 2003 10:41 am
hcromeo wrote:Where does the rear sway bar go?
Sway bar links the left suspension to the right suspension.
When you corner, the inner suspensions have the tendency and the outer suspensions will be pressed down creating body roll. When you have a thicker swaybar, the outer suspension will force the inner suspensions down minimizing bodyroll thus getting more traction to the inner tires.
impactX
Postby WTF?? » Tue Aug 05, 2003 11:24 am
impactX wrote:If you don't like to sacrifice the ride quality for performance, you shouldn't modify it in the first place.
Sounds like a Flipside909 answer!! :lol: :lol:
Maybe hes rubbing off on some of us :wink:
Retired... its been fun Image
WTF??
Postby Jai_Jai_Binks » Tue Aug 05, 2003 12:12 pm
Ryan is nothing what you all are...or will become! his knowledge will always amaze me...especially since he's like memorized the whole $hit! not to sound like an Ahole :agrue: but i just wanted for someone to comment on the ride quality. In the world of modders, there are those who go for looks, and there are those who go the forced induction route. What suites me, is what suites me....not what i think migh look cool to others. Surely, i've got a kit, surely...i've got wheels..but there's always something lacking in the car in my mind....I agree I need to lower it...but you should drive in Houston roads..to see how NOT to scrape your kit! I don't want to start something by the end of which we would need missay coming and being like the UN or something...bottom line PEACE!
Postby impactX » Tue Aug 05, 2003 4:20 pm
I have no kit on my car. The quality of Vancouver road is as rough as sex without lubrication. Potholes everywhere and repaved roads are worse than the non-repaved ones. Anyways, I still have the car lowered on Eibach with Bilstein, it still won't scrape anything since it's not a dramatic drop.
In stock form, you basically won't know what the road surface is like because you won't feel a thing from the steering wheel. I enjoy driving because of the feedback it gives me. I know how fast to take a turn using this feedback.
impactX
Postby xXsolaraXx » Tue Aug 05, 2003 10:14 pm
:o :x MEOW!!! :x
xXsolaraXx
Postby cdssolara » Tue Aug 05, 2003 11:54 pm
I have the TRD rear sway bar on TRACK setting, and the Whiteline front sway bar. I also have Eibach springs and Tokico struts. My ride is a lot firmer than stock, but I wouldn't go back to the boatlike stock ride for anything. The sway bars make the ride a bit firmer in the front, but it's mostly noticeable when only one of the front wheels hits a bump. Since the streets where I live are pretty horrible, I've stuck with a 16" wheel, although I use 225/55 tires with a 7 1/2" wide wheel. They don't look quite as good as 17's, but they give me a little more comfort on potholed streets.
cdssolara
