SolaraGuy.com • View topic - 17 x 9 inch wide???
17 x 9 inch wide???
17 x 9 inch wide???
Postby K1llertwo » Sun Feb 21, 2010 7:44 am
anyone rolling some dub style wide ass lips vip style??? sorta feeling that style for a solara... I was checking these out
http://www.wheelsnext.com/wheels-tires- ... Gloss.html
then saw these for sale close to my house
http://montreal.kijiji.ca/c-cars-vehicl ... Z181476369\
Will this probably not fit?? even with spacers and a fender roll??? or will I have to go WIDEBODY???
I<m getting all sorts of parts, building it and it'll be ready and a suprise this summer
K1llertwo
Postby .onetohate » Sun Feb 21, 2010 11:15 am
9 wide in the 23-28 offsets. roll/pull/camber for the rears-
8.5 +29-30ish for the fronts-
it also depends if yr lowered, cambered, etc..
.onetohate
Postby K1llertwo » Sun Feb 21, 2010 1:16 pm
.onetohate wrote:9 wide in the 23-28 offsets. roll/pull/camber for the rears-
so...
7mm spacer in the back (35 is original offset) and a roll and a pull and a camber?
and the front 9'' is impossible...?
I'm still in the process of research for lowering: if I want to get a camberkit, figuring out what I need before: If I wanted to run this extreme setup, what is everything i'd need
rims, appropriate non-rub tires, fender roll,fender pull, camber kit...??? and then...
I've got the springs and struts, what else should I look into changing while i'm there ( bushings ? ...)
I want it to be a one shot trip to the garage...
K1llertwo
Postby scamry » Sun Feb 21, 2010 2:26 pm
if you are only going to be on springs and struts, then 17x9s are going to look strange, and you won't be able to get much camber with the combo.
and don't buy sportmax wheels.. try zilvia for some nice wheels with nice specs.....
scamry
Postby t3chnique » Mon Feb 22, 2010 10:45 am
scamry wrote:if you are only going to be on springs and struts, then 17x9s are going to look strange, and you won't be able to get much camber with the combo.
^ X2. No way 9' in front is gonna look good with springs and struts. Widest I'd go is 7.5-8". If you want 9" up front, get some coilovers or air ride and camber in.
Oh and those wheels you linked aren't even close to "VIP styled"...
t3chnique
Postby Toy1mzfe » Mon Feb 22, 2010 3:38 pm
Springs strut + 17x9= too much fender gap...
will look like a 4x4. Unless you meat up the tire but then you will rub...
Postby K1llertwo » Mon Feb 22, 2010 6:29 pm
thanks guys, ill keep looking... i'm not into the truck look. lol
I like the deep dish wide lip look,
anyone got suggestions on some wheels?
K1llertwo
