SolaraGuy.com • View topic - couple of strut/spring questions.
Postby corlon » Fri Mar 19, 2010 3:08 pm
is anyone running tokico hp front struts with stock springs? can you describe the ride quality? also, does anyone know the least amount of drop for aftermarket springs for the front? 1st gen v6 5-spd. thanks.
NiCe
corlon
Postby MisterTedster » Fri Mar 19, 2010 3:43 pm
Even when dropped with tokicos and eibachs the ride quality is just slightly harder than stock. Also, the eibach springs should give you the smallest drop, which I believe is 1.5" or so.
02 SE V6
MisterTedster
