SolaraGuy.com • View topic - Quick Question: What is the biggest tire size...
Postby SirMacDaddy » Tue Mar 23, 2010 5:40 pm
What is the biggest tire size that can fit a gen. 1 with gen. 2 rims? I have stock suspension as well as 15mm spacers in the back. I am willing and able to roll the fenders in the back.
I need to get tires ASAP and i want to get the biggest possible to fill up the wheel well.
I have tried searching this, but I couldn't find someone with the similar question that had the same or similar specs.
Thanks for your time
Omar
SirMacDaddy
Postby 99BlackSandv6 » Tue Mar 23, 2010 6:12 pm
Wrong thing to do. Just get the stock size. If you want to properly fill the wells, get proper wheels and tires. seriously
Postby SirMacDaddy » Tue Mar 23, 2010 6:37 pm
Okay...what is the stock tire equivalent for 17inch rims?
SirMacDaddy
Postby AutoBlasian » Tue Mar 23, 2010 6:41 pm
SirMacDaddy wrote:Okay...what is the stock tire equivalent for 17inch rims?
check this out, it helped me
http://solaraguy.com/viewtopic.php?t=48601
2001 Black Toyota Solara SLE 3.0 V6 Auto
AutoBlasian
Postby 99BlackSandv6 » Tue Mar 23, 2010 8:13 pm
Should be a 215/50/17.
Postby ToyoSolV6 » Tue Mar 23, 2010 9:49 pm
When i got my gen2's they came with 215/55r17
I went through many different tires to see which one fits the best. I would not recomend trying to fit the whole wheel well by getting big arse tires! its going to look like a truck! lol
and if you ever want to lower the car its going to rub like crazy.
If you want something with a nice look to it and still a comfortable ride i would say run 225/50r17 thats what i have.
DO NOT run anything wider than a 225 without spacers in the rear because you will rub against the strut.
hope this helped.
Postby Sol_MTL » Wed Mar 24, 2010 7:46 am
ToyoSolV6 wrote:When i got my gen2's they came with 215/55r17
hope this helped.
I am contemplating between 215/50/17 and 225/50/17 for my '99 I4...Did you have any issues with the 225's, and are you lowered?
Sol_MTL
Postby ToyoSolV6 » Wed Mar 24, 2010 8:35 am
i had no issues with 225's and yes i am lowered.
Postby jimmm » Wed Mar 24, 2010 9:10 am
Several resources show the following:
2004 Toyota Camry Solara SLE
Original equipment tire size:
P215/60R16
Alternate tire size also available:
P215/55R17
My car came with the Alternate size which I like just fine.
jimmm
Re: Quick Question: What is the biggest tire size...
Postby zdutch1 » Thu Mar 17, 2016 7:07 pm
Costco told me I need to have 215/55/16 but how wide can I go with those SLE V6 wheels?
Thanks
zdutch1
Users browsing this forum: No registered users and 141 guests
