SolaraGuy.com • View topic - Tokico HP
Tokico HP
Tokico HP
Postby Sol_MTL » Sun Mar 28, 2010 2:28 pm
Quick question: I was on the Tokico site App chart and for Solara it says Solara (MCV20) 99-03...(HP Series)
Is the MCV20 a chassis code or what? I have the I4 5S-FE and want to know if these struts will fit. Thanks :)
Sol_MTL
Re: Tokico HP
Postby monksta408 » Sun Mar 28, 2010 3:36 pm
Sol_MTL wrote:Quick question: I was on the Tokico site App chart and for Solara it says Solara (MCV20) 99-03...(HP Series)
Yes, I believe that is the chassis code or platform number. Im not sure if the same Tokico struts will fit both models though. The code for the V6 1MZ-FE platform is MCV20, but I think the code for the I4 5S-FE is SXV20. But it looks like the struts could fit all sub models from 99-03. I think the difference would just be in the springs. Lil confusing though. Hope that helps a lil. lol... :think:
_____________________________________________
monksta408
Postby Sol_MTL » Sun Mar 28, 2010 5:08 pm
Yeah I think you're right about SXV20 being for the 5S-FE...
Anyways I jus wanna be 100% sure before ordering them, if anyone has Tokico Blue's on their I4 please post!
Sol_MTL
Postby SirThomas8 » Sun Mar 28, 2010 6:46 pm
Just make sure you get the Tokico's for the 4 cylinder and not the 6 cylinder.
SirThomas8
Postby Sol_MTL » Tue Mar 30, 2010 8:31 am
Ive also been told by a couple people that with the Eibachs the car will ride very rough up front because of the difference in weight because i have the 4cyl...
Sol_MTL
Postby monksta408 » Thu Apr 01, 2010 8:55 am
Yeah, Im pretty sure the springs are gonna be a lil different between the 4 and 6 cylinder because of the different ride heights and spring rates due to the weight factor. :think:
monksta408
Postby CamryOnBronze » Thu Apr 01, 2010 12:15 pm
If you put 4 cylinder springs on the front of a V6, it will sit a little bit lower. Otherwise, I really don't think it will make much difference. I can't see tokicos and lowering springs riding very rough...
Postby Sol_MTL » Thu Apr 01, 2010 2:08 pm
CamryOnBronze wrote:If you put 4 cylinder springs on the front of a V6, it will sit a little bit lower. Otherwise, I really don't think it will make much difference. I can't see tokicos and lowering springs riding very rough...
Alright thanks for the advice. Perhaps the guy just didnt understand i was putting Tokico's to GO WITH the Eibach springs as opposed to stuck struts....
Also, went to a few shops around here to see if I could get them to order the parts for me (im still wary of ebay) and the prices i got quoted seemed ridiculous... like $400+ for the springs, wtf lol.
($CDN dollars mind you)
Sol_MTL
Postby turboman412 » Wed Apr 28, 2010 2:05 pm
there's no diff in the springs. if you look at eibach's website there part numbers are listed for both 4cyl and 6cyl......
turboman412
Postby SirThomas88 » Wed Apr 28, 2010 2:13 pm
when I ordered my Intrax springs there was definitely different part numbers for the 4cyl and 6cyl
SirThomas88
