SolaraGuy.com • View topic - dash wood trim peeling
Postby lildk50 » Fri Aug 08, 2003 4:24 pm
does anyone know how i can fix my central console surround? It's peeling b/c the ungodly heat of houston.
lildk50
Postby Jackass-Jeff » Fri Aug 08, 2003 4:40 pm
add on wood dash stuff? if so... glue melts =\ nothing you can really do =x unless you get a high temperature glue (it would work... but I don't even know if it exists =x )
1GR-FE ftw!
Jackass-Jeff
Postby mrdish » Fri Aug 08, 2003 5:53 pm
My add-on wood dash was peeling and I used something called "Weldbond" and so far so good. Gets a little warm here in Vegas, only got up to 108 today.
Steve
Sorry 'bout that, consequences of my childhood.
mrdish
Postby lildk50 » Fri Aug 08, 2003 8:13 pm
mrdish wrote:My add-on wood dash was peeling and I used something called "Weldbond" and so far so good. Gets a little warm here in Vegas, only got up to 108 today.
Steve
so all i do is apply the weldbond to the peeling plastic n press against the dash trim n thas all? Ballin' :multi:
lildk50
Postby mrdish » Sat Aug 09, 2003 7:33 am
You apply to both surfaces, the dash and the peeling trim. Wait for for about two minutes then press the peeling area to the dash and hold for about a minute.
I try not to let the sun hit the dash directly by parking away from the sun and using a window sun shield.
mrdish
Postby chef solara » Sat Aug 09, 2003 10:48 am
All I did was ripp it all off, I live in south FL, I had the same problem in just under two years old. So I took it all off. I will be getting something else maybe.
chef solara
