SolaraGuy.com • View topic - downgrading from coilovers to springs/struts
Postby tweazy » Sat Apr 03, 2010 8:49 am
My JIC coilovers (and 19" rims) are shot and I have decided to go back to springs/shocks setup. Does anyone have experience with Megan Racing lowering springs? They seem to have the lowest drop for the Solara application. I am thinking about pairing it with Tokico struts along with 18" rims (235/40/18 tires). Any thoughts?
Thanks guys!
Also, where do I get upper strut mounts?
Megan Racing
Color: Orange
Lower rate: 2" Front, 1.7.5-2" Rear
Springs rate: 300F & 250R
MSRP: $149
http://www.meganracing.com/products/product_detail.asp?prodid=274&catid=47
tweazy
Postby GreeKAvaLoN » Sat Apr 03, 2010 3:11 pm
i think i've heard of them sagging more in the rear, im not too sure though. stiffer then most, but sag in the rear? JIC won't rebuild ur coilovers? maybe that'll be cheaper
GreeKAvaLoN
Postby Toy1mzfe » Sat Apr 03, 2010 3:29 pm
Join the group... Went back to Tein Stechs... Miss my drop.
Go and Do megans. Dont think Any Solara guy have megans besides camrys.
Postby t3chnique » Sat Apr 03, 2010 5:09 pm
Tenzo GF-2s have a similar drop. 2" all around. Fit Camrys/Solaras 97-01. I have a set for sale plus a set of TEIN rear springs, pm if interested.
t3chnique
Postby tweazy » Sat Apr 03, 2010 5:23 pm
GreeKAvaLoN wrote:i think i've heard of them sagging more in the rear, im not too sure though. stiffer then most, but sag in the rear? JIC won't rebuild ur coilovers? maybe that'll be cheaper
I thought about rebuilding the coilovers. The dampers are replaceable for the FAS model but mine makes weird clunking noises. It could be the bad dampers or bad upper mounts but I've lost interest to investigate (lazy). I just want a cheap way to remedy this. A spring/strut setup is cheaper than getting it rebuilt.
tweazy
Postby tweazy » Sat Apr 03, 2010 5:25 pm
Toy1mzfe wrote:Join the group... Went back to Tein Stechs... Miss my drop.
So you had megan's before? What made you switch to Tein?
tweazy
Postby tweazy » Sat Apr 03, 2010 5:31 pm
My new rims BTW.
Tenzo DC-6 Version 2
18"x8"
tweazy
Postby Mr_Krispy1183 » Sat Apr 03, 2010 6:26 pm
Are your/Steve's C5s dunzo?
Also, for 18x8, I'd do 225/40 or 225/45. 235s, would likely rub quite frequently.
Postby Toy1mzfe » Sun Apr 04, 2010 1:57 am
naw i was also on JICs then went back to spring shocks.. Tein+kyb
Postby tweazy » Sun Apr 04, 2010 2:50 am
Mr_Krispy1183 wrote:Are your/Steve's C5s dunzo?
Yeah, it's Steve's old 19" C5 3-piece. I bent 2 rims in one day running over one huge hole on the freeway.
I got the tire 235/40/18 already mounted and they seem to be fine with my blown coilovers. Some slight rubbing in front when driving over bumps/dips though.
tweazy
Postby tweazy » Sun Apr 04, 2010 2:54 am
Toy1mzfe wrote:naw i was also on JICs then went back to spring shocks.. Tein+kyb
Ah I see.
I am gonna try Megan's then with Tokico struts.
Thanks for the input guys!
tweazy
