SolaraGuy.com • View topic - Goodridge SS brake lines for Ericsol/ES300 brake swap
Postby SolaraPete » Sun Apr 04, 2010 5:16 pm
Ive accumulated almost everything for the ES300/TT front and rear brake swap, except the steel lines. Do i need to order the lines for an es300 (#21063) or for the solara (#21064)? I wouldnt think there would be too much of a diff between them, but they are diff part#'s so i wanna make sure i get the right ones...
SolaraPete
Postby sydemoid » Sun Apr 04, 2010 5:56 pm
Use the Solara ones, I have them on mine, no issues, I think they might be the same, but the ES300 lines might differ in how they mount on the ES300 vs. a Solara.
The feeders should be the same, allowing you to couple them to your calipers without a hiccup.
Might I suggest upgrading to DOT4 brake fluid?.... Currently I use ATE blue racing Dot4 brake fluid... works like a charm!
sydemoid
Postby SolaraPete » Sun Apr 04, 2010 7:53 pm
I was thinking the solara ones would prob be the correct choice - but i hate having to return anything from ebay so thanks for your confirmation :sweet:
Good call on the brake fluid - thats def getting changed as well!
SolaraPete
Postby SleeperSolara » Mon Apr 05, 2010 3:10 pm
The Solara SS Goodridge brake lines will work wit the ES300 twin piston calipers.
Just be sure you have the banjo bolt from the ES300 twin piston calipers.
