SolaraGuy.com • View topic - Custom Spring Rates
Custom Spring Rates
Custom Spring Rates
Postby chullen1 » Mon Apr 05, 2010 11:39 am
I am getting d2 coilovers soon and want some info on custom spring rates. I have a heavy sound system in the trunk that currently makes the stock shocks and springs sag. The d2 coilovers have 8.7 in the front and5.1 in the rear. I was thinking of getting a heavier rear spring. Any thoughts on how heavy would be great.
chullen1
Postby ThatVietGuy » Mon Apr 05, 2010 3:33 pm
12 front, 10 rear :drinking:
6 or 7 kg/mm in the rear would probably be best to counteract the weight without having to change the rate for the fronts.
ThatVietGuy
Postby chullen1 » Tue Apr 06, 2010 10:51 pm
how stiff is 12kg/mm in the front and 10kg/mm in the rear
chullen1
Postby ThatVietGuy » Tue Apr 06, 2010 11:31 pm
Ridiculously stiff.
ThatVietGuy
Postby 99BlackSandv6 » Wed Apr 07, 2010 2:31 pm
10kg/mm = 560lb/in.
12kg/mm = 670lb/in. Yeah, that's stiff. (twss) :lol:
Postby 99BlackSandv6 » Wed Apr 07, 2010 2:37 pm
The out of the box 5.1 that the D2 has, is 285lb/in.
If you went to a 6 it would be 336lb/in.
At 7 you would have 392lb/in.
You'd probably be fine with a 6. How much extra weight do you have in the trunk?
FYI 1kg/mm = 56lb/in. :sweet:
Postby CASTRO » Thu Apr 08, 2010 8:26 am
just to chime in,
I have coilovers on both my cars: Camry and S2000
The Camry has the JIC Magic FLTA2-RS
The S2000 has T1R fully adjustables
The S2000 runs much higher rates than the camry @ 10kg and to me it feels soft still since the dampening is so good. I forgot what the rates for the JIC Magics are but IMO you'd want to get at least 8+ in the rear as its a bigger car. Make sure they match the dampers to the springs or it could get bouncy/rough ride real fast.
CASTRO
Postby chullen1 » Thu Apr 08, 2010 9:22 pm
I have about 50 to 60 extra pounds with the sub box and floor and extra dynamat. I am thinking either 10kg/mm and 8kg/mm or 9kg/mm and 7kg/mm? I will contact gabe and see what he thinks.
chullen1
Postby chullen1 » Thu Apr 08, 2010 9:26 pm
I just looked at the JIC Magic's they have two kinds one with a 5kg/mm rear spring and one with a 6kg/mm rear spring. I might go with 9kg/mm and 7kg/mm for the spring rates.
chullen1
Postby CamryOnBronze » Fri Apr 09, 2010 9:48 am
I would call the manufacturer themselves and ask them what they think. They are going to know best since they did the R&D to decide what their standard spring rates for the car would be. And FYI, I read on Zilvia that JIC has gone belly up and is trying to liquidate everything- they might not be a source for custom springs anymore. I don't know for sure, but I heard they have everything in stock on a clearance sale, so I wouldn't doubt it.
K-Sport does custom rate springs though, if I remember correctly.
Postby chullen1 » Fri Apr 09, 2010 10:36 pm
Yeah, I might call them this week. I know D2 racing is still in business. I think 9kg/mm and 7kg/mm will be awesome with the 36way rebound and damping control these coilovers have.
chullen1
Postby bigbirdSCed » Sun Apr 11, 2010 5:25 pm
Boostedsupra, or something like that, from TN was selling a brand new set for a good price a while back that never sold as far as i know...hes local too, lives south of B-more.
CASTRO wrote:just to chime in,
anything higer then like 7 for the camry will be too much and youll start to compromise handling. My buddie's S has much stiffer spring rates but because they are more expensive and designed specifically for the S they dont fee that stiff. even the expensive C/O systems are just reworked to fit the solara/camry chassis. so the dampening is matched to the spring rate...and not the car.
6 should be fine.
bigbirdSCed
