SolaraGuy.com • View topic - Spacer Question
Spacer Question
Spacer Question
Postby kteng » Fri Apr 09, 2010 10:58 pm
Just wondering if the 3mm Wheel Spacers can be install on regular wheel studs for safe usage? and how many lug nut turns require for safety? Thanks!
kteng
Postby .onetohate » Fri Apr 09, 2010 11:34 pm
i believe you CANNOT run any spacer without extended studs- its just flat out unsafe. Running spacers is an expensive affair, don't cut costs during a project like this because it's what connects your car to the road.
.onetohate
Postby ThatVietGuy » Fri Apr 09, 2010 11:59 pm
80 ft-lbs of torque and three full turns of the lugnuts should be safe.
I'm pretty sure up to a 5mm spacer is safe enough without having to resort to extended studs.
ThatVietGuy
Postby Toy1mzfe » Sat Apr 10, 2010 12:22 am
^^^ i agree
Postby kteng » Sat Apr 10, 2010 7:56 am
Thanks guys!
kteng
