SolaraGuy.com • View topic - Reverse glow gauges
Reverse glow gauges
Reverse glow gauges
Postby MarcoSolara02 » Wed Apr 21, 2010 5:19 pm
I still need help on installing Revere Glow Guagues, anyone In the valley that can help me out? Shops are charging wayt too much.
[img][IMG]http://i116.photobucket.com/albums/o17/s14marco/0702001319a.jpg[/IMG][/img]
18" SSR Wheels, 20 % Tint all around, Trd muffler, Eibach/Tokico.
MarcoSolara02
Postby MisterTedster » Wed Apr 21, 2010 11:00 pm
It's really not so hard. Basically you have to bend the gauges to get it around the needles. They look great with a brushed aluminum bezel btw.
02 SE V6
MisterTedster
Re:
Postby DSM_Lara » Sat Jul 17, 2010 4:18 am
MisterTedster wrote:It's really not so hard. Basically you have to bend the gauges to get it around the needles. They look great with a brushed aluminum bezel btw.
I been looking for a clean and simple gauge cluster for a while and finally found the one I will settle for. All the other clusters was to busy for me and a little ricey in my opinion. These are the one I just ordered. ^^^^^
Can't wait to get them in. Once I do receive them I'll add a TRD decal in the middle cluster. So, when it glows at night it should light up with the TRD Logo.
DSM_Lara
Re: Reverse glow gauges
Postby TheMack » Sat Jul 24, 2010 4:12 am
how can ya actually get to the gauges to put these ones in cuz i have the same ones too
TheMack
Postby kenny6683 » Sat Jul 24, 2010 10:46 pm
-put the steering wheel on lowest position..
-remove two screws holding the plastic bezel around the cluster then pull that off
-now remove the screws holding in the cluster
-pull cluster from the top forward towards you...unplug the green plugs behind it
-move it around until you figure out the right angel to get it out of the dash
-on the backside of the gauge cluster you will see the tabs of the plastic frame in place...just remove the tabs from back side and the plastic frame comes off easy
-once you have access to actual gauges just take the screws off the front and put them aside for a second
-take the new gauge face and slide them on over the old ones. thats right! the old ones don't come off
-then put screws back on.
-replace the plastic frame over the cluster...wires may give you a hard time closing the lid again since now its a tight fit, so you can get a box cutter and cut the plastic a small bit to give them passage space (hope this makes sense to you)
-plug the new face wires together and get your positive "red" connected and black negative connected
replace everything else you removed earlier...and your done! (green plugs only fit into the same port they were removed from so be worried about plugging them in incorrectly)
kenny6683
Postby toyokid » Tue Oct 19, 2010 5:23 am
i kno this may sound stupid but which wires am i connecting the new wires to?
toyokid
Postby MisterTedster » Tue Oct 19, 2010 12:43 pm
iirc, I believe its a green wire that's on the far right of the brown connector.
02 SE V6
MisterTedster
Postby toyokid » Thu Oct 21, 2010 2:57 am
cant u remove the needles? just pull them straight out?
toyokid
Postby MisterTedster » Fri Oct 22, 2010 12:51 pm
no, they're attached permanently. You have to bend the gauges around them to put it on.
02 SE V6
MisterTedster
Postby SPICA1750 » Sat Oct 23, 2010 5:01 pm
Awesome gauges. What site can you get them off of?
2000 Toyota Solara SE<aftermarket exhaust>
1995 BMW 525i..(sold)
SPICA1750
Postby MisterTedster » Sat Oct 23, 2010 7:01 pm
ebay, they list 'em for the camry.
02 SE V6
MisterTedster
Postby SPICA1750 » Sun Oct 24, 2010 11:29 am
MisterTedster wrote:ebay, they list 'em for the camry.
Thanks! i searched em but it seems sketchy buy that kind of stuff on ebay
SPICA1750
