SolaraGuy.com • View topic - exhaust and rev
exhaust and rev
exhaust and rev
Postby 5842solara sc » Fri Apr 23, 2010 10:08 am
hey
with boosted 1mz what size exhaust piping would you go?
and
whats the max rev limit you think is good? is it the factory 6200 or do you think we can go 6500?
thanks
5842solara sc
Postby Dawgz » Fri Apr 23, 2010 10:21 am
2.5 - 3"
Postby stringbean » Fri Apr 23, 2010 10:37 am
2.5 - 3 is good size, wouldn't go smaller, maybe 2.25 if your wanting to run a true dual exhaust but still then maybe a 2.25 - 2.75" also i would bump your rev limiter unless you have built internals other wise 6200 is good, with built internals you might be able to get away with 6750 it depends on a lot of factors, and also how built you go, also if your built you'll automatically have gained more hp if you did it right and went the extra mile lol, good luck
stringbean
Postby 5842solara sc » Fri Apr 23, 2010 11:28 am
thanks for the info..
what are you guys running for exhaust
2000 V6 SC'd 6lbs..
lighted crank pulley
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby stringbean » Fri Apr 23, 2010 11:32 am
im not boosted but im running a brand new oem y pipe, 2.25 size pipe to a cat then to a oem resonator, then to a "muffler" i made from a resonator and a exhaust tip that i made 4" diesel exhaust pipe, round rod and powder coated it all, sounds pretty beefy and not like a fart can. added a bit of hp, not as many restrictions, i went as straight as possible. i do a lot of custom work.
stringbean
Postby stringbean » Fri Apr 23, 2010 11:35 am
but the greddy evo 2 exhaust is very populor on our 1mz, also megan cat back racing is popular as well, and obx headers and y pipe for the hole exhaust system
stringbean
Postby Dawgz » Fri Apr 23, 2010 12:47 pm
Greddy Evo II is what im using.
Postby usoff89 » Fri Apr 23, 2010 1:39 pm
Just purchased my OBX headers and full 3inch exhaust. Don't have it yet, but have heard good things about it.
Also if you are boosted, and plan on some day going with higher boost than stock then I would go with 3inch all the way back. Just my two cents
99 SuperCharged Lara
14.7@93 on 1/4mile (average)
Fastest run so far - 14.65@93
4.5psi
usoff89
Postby 5842solara sc » Fri Apr 23, 2010 1:46 pm
lol ok thanks.. mayb i just go with 2.5? idk
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby trd4life » Fri Apr 23, 2010 3:18 pm
3"
Postby bbq bob » Fri Apr 23, 2010 6:43 pm
i have the obx headers and 3" exhaust . boosted with 6 lb. pully . works real nice .
bbq bob
Postby 5842solara sc » Fri Apr 23, 2010 9:25 pm
ok... i guess 3" .. lol
i wanna go tru dual.. i hope you guys know that... not single in dual out
2000 V6 SC'd 6lbs..
cpe intake
255 fuel pump
supra injectors
5842solara sc
Postby 99BlackSandv6 » Sat Apr 24, 2010 1:30 am
For duals you should go smaller than 3. I'd say no bigger than 2.5 if you are running true duals. Remember it's a small engine.
