SolaraGuy.com • View topic - weapon r "secret weapon" or injen
Postby 20in2000solaraguy » Fri Apr 30, 2010 11:39 pm
which one is better for 1 gen solara?
20in2000solaraguy
Postby MisterTedster » Fri Apr 30, 2010 11:43 pm
I4 or V6?
02 SE V6
MisterTedster
Postby 20in2000solaraguy » Fri Apr 30, 2010 11:57 pm
L4
20in2000solaraguy
Postby Sasebo » Sat May 01, 2010 12:00 am
Injen.
Sasebo
Postby mightymouse402 » Sat May 01, 2010 1:26 am
Injen
That's what she said...
mightymouse402
Postby 20in2000solaraguy » Sat May 01, 2010 8:40 am
what about this? or it's just bull?
"Do the Weapon*R Air Filters, filter dirt better than K&N / AEM / Injen Air Filters?
The Secret Weapon Air Filter is made of Polyeurethane Foam, which is rated at 300 Pores per square inch. Whereas the K&N / AEM / INJEN air filters are rated at 30-60 pores per square inch. This means that there is more dirt particles passing through the air filter to the engine when using their filters.
Why is the Secret Weapon Air Filter so much better?
The reason why the Secret Weapon Air Filter flows much better than any other filter on the market today is because of the specially designed Velocity Stack inside the air filter, it helps gather more air into the air filter and velocitize the air into the intake tube".
http://www.prostreetonline.com/x/weapon ... ntakes.asp
20in2000solaraguy
Postby Mr_Krispy1183 » Sat May 01, 2010 11:48 am
K&N filter is the way to go.
Postby Midias » Sat May 01, 2010 3:42 pm
if you have the 5s engine the pipe does not matter just get the ebay special and a good filter.
Postby TadS » Sun May 02, 2010 8:56 pm
Midias wrote:if you have the 5s engine the pipe does not matter just get the ebay special and a good filter.
x2
TadS
Postby Kenz » Sun May 02, 2010 8:59 pm
Secret weapon? haha thats some funny crap
- Mack
Silver `03 i4 5 Speed
Dropped w/ Tein & KYB
OBX Cat Back
Kenz
