SolaraGuy.com • View topic - Ice cold SC after WOT runs
Postby sarki » Wed May 19, 2010 4:53 pm
Yup you read it correctly. Greg finally installed the Meth kit on the car using a dual nozzle setup (One before the blades 375 m/l and one after 175 m/l) and it keeps the sc really cold after several WOT runs. Almost too cold. You can put your hand on the sc and it feels like the cars not even on! Now the problem is finding out if the nozzles are too big. Quenching is the key but i may be over spraying right now.It doesn't feel like the car is bogging but it could run a little crisper. Once i get the car dyno tuned, We can figure out if im running too rich or just too much Meth. I'll try to put up pics of the install later.
Who wants to buy it?
sarki
Re: Ice cold SC after WOT runs
Postby SleeperSolara » Wed May 19, 2010 7:45 pm
Nice man.
Postby KILLA CAM » Wed May 19, 2010 9:14 pm
Pics of set up please! Would be very appreciated!!!
Thanks again for hooking us up with these kits sarki, I should have mine installed in the next month!
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby 2wickedtoyz » Thu May 20, 2010 9:23 am
any updates yet? this is some good to know stuff
2wickedtoyz
Postby ToyoSolV6 » Fri May 21, 2010 12:45 pm
Nice bro i should have hopped on this when i had the chance but i had no money at the time, anyways hit me up when you go get it tuned i wanna be there.
Postby sarki » Sun May 23, 2010 3:27 pm
Hey guys sorry but no update yet. I'm going to try to schedule a dyno session for next week at Church's. I'll let you know Fergi.
sarki
Postby sarki » Mon May 24, 2010 9:17 pm
Here are some cell phone pics. Sorry but its not the best quality.
Here's the reservoir tank that came with the kit. Greg made a custom bracket and mounted it on the bumper support.
This is the Solenoid upgrade. You need this if your installing your first nozzle "After" the throttle body.
This is the first nozzle. Its a 375 ml nozzle. We tapped directly into the SC right after the throttle body and before the blades/screws....whatever you want to call it. We realized tapping into the throttle body spacer sounded like a great idea, but wouldnt work.
This is the second nozzle tapped into the SC after the blades. The nozzle is a 175 ml. The only problem im having is with the TRD strut brace. The nozzle hits the brace when i gas it up in reverse. My mount is no good. But i dont really need the brace right now.
The kit comes with warning led lights. Here's where we put mine. Green led indicates that the pump is on and the red is a low meth indication light.
Greg had a great idea with the controller. Since i dont use my ash tray, We put it in that location.
sarki
Postby Mr_Krispy1183 » Mon May 24, 2010 10:37 pm
Sark,
you need Greg's solid rear mount. Makes a world of difference.
Postby yaddadaimsayin » Mon May 24, 2010 11:04 pm
Mr_Krispy1183 wrote:Sark,
no homo
Postby EEngineer » Mon May 24, 2010 11:08 pm
clean install but why would the TB spacer tap not work? cuz the TB flap valve would hit the nozzle?
94 Camry 3VZ 5 spd swapped - parted out 2009
92 ES300 3VZ 5 spd supercharged @ 300.8whp
99 Solara 1MZ 5 spd bone stock (not for long)
EEngineer
Postby sarki » Tue May 25, 2010 8:37 pm
EEngineer wrote:clean install but why would the TB spacer tap not work? cuz the TB flap valve would hit the nozzle?
Yes. Wont work on the front or back. Top would be too high and the bottom was a weird design we couldn't get the nozzle flush. So we said fuk it.
Hay Brian, ill get the mount done at a later time. I know that's where my problem is.
sarki
Postby SirThomas88 » Thu May 27, 2010 12:43 am
That's awesome dude. can't wait to hear what you learn at the dyno.
i thought the typical thing to do was to mount the meth injector before the TB, but after the MAF, by drilling a hole right into the side of the Injen/OBX or whatever aftermarket intake one might have.
SirThomas88
Postby sarki » Thu May 27, 2010 3:46 pm
SirThomas88 wrote:That's awesome dude. can't wait to hear what you learn at the dyno.
If you do not want to tap the SC and spend money on a solenoid upgrade, You can just tap the intake. I went a little extreme with Gregs "Mega Mods" ideals. LOL. It all depends on what your trying to achieve. I was going for maximum safety at WOT. Its ok both ways. Oh btw if you guys are planning on getting a throttle body spacer, Get the one i have. Its the Helix Power. It makes the car sound like it has a turbo and its spooling up at low speeds/throttle. Sounds kinda cool. :bday:
sarki
Postby SleeperSolara » Thu May 27, 2010 7:59 pm
Looks good man.
Postby hskrsolara » Fri May 28, 2010 7:13 pm
i plan on spraying in the injen, not risking tapping the supercharger. Especially with the rarity of these sc's, there's no way im risking the integrity of the blower.
props on your install sarki, it looks clean. i'm just not going to risk tapping the charger.
hskrsolara
Users browsing this forum: Google [Bot] and 24 guests
