SolaraGuy.com • View topic - New 07-10 TRD wheels fit a gen 4 camry
Postby chullen1 » Thu Jun 03, 2010 10:59 am
I have been looking for a set of wheels I like, and found them with the new TRD wheels for the newer camrys. The wheels are 18x7.5" and are 5.114.3. The offset is 45mm. Will this wheel work on a gen 4 camry. I know the my camry has a 5x114.3 but am unsure if the offset is too high. If not what do you think about these wheels? I have included a link to the wheels.
http://cgi.ebay.com/ebaymotors/Toyota-C ... 20ace6cd33
chullen1
Re: New 07-10 TRD wheels fit a gen 4 camry
Postby SleeperSolara » Thu Jun 03, 2010 11:29 am
chullen1 wrote:I have been looking for a set of wheels I like, and found them with the new TRD wheels for the newer camrys. The wheels are 18x7.5" and are 5.114.3. The offset is 45mm. Will this wheel work on a gen 4 camry. I know the my camry has a 5x114.3 but am unsure if the offset is too high. If not what do you think about these wheels? I have included a link to the wheels.
They should work.
+ 45 offset is good i think.
The Gen 2 Solara rims are + 50, so you'll need spacers in the rear if you use Gen 2 rims.
You might need maybe 5 mm spacer in the rear.
Postby KILLA CAM » Thu Jun 03, 2010 12:31 pm
Mount some 215/45/18 tires on there and you'll be good to go.
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby 1st Gen Sol » Thu Jun 03, 2010 1:32 pm
Check this guy out over on ToyotaNation.com. He has a set that he was trying to sell awhile back, from what I know he still has them.
http://www.toyotanation.com/forum/showt ... p?t=338759
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby ToyoSolV6 » Thu Jun 03, 2010 2:37 pm
ive always liked those wheels.
they look nice.
Postby chullen1 » Thu Jun 03, 2010 7:49 pm
I wanna run a 225/45/18 is that too big for the camry. I will have D2 Racing Coilovers soon.
chullen1
Postby kingkakyle » Fri Jun 04, 2010 2:53 pm
225/45/18 is what a 02-current camry 04+ solara would run
so it might be too big for ur camry
Postby hskrsolara » Fri Jun 04, 2010 8:46 pm
I run 17x7 2005 avalon wheels (blacked out) on my solara. 45 offset. I have shaved rear fenders and am running a 15mm spacer on the rears. It is damn near perfect, I am really happy with the fitment. For your case, I would consider 5mm or 10mm spacers. 5mm would do the trick, but 10mm would look more flush. If you're not rolling the rear fenders, i would stick with the 5mm spacers and that would give you sufficient clearance for the strut..
If you need 5mm hubcentric spacers with extended lugs, let me know, I have a set of H&R 5mm for sale.
hskrsolara
Postby KILLA CAM » Fri Jun 04, 2010 10:55 pm
kingkakyle wrote:225/45/18 is what a 02-current camry 04+ solara would run
If you want 225 series you'll need to run a 40 sidewall. You'll probably end up with rubbing issues and your speedometer and mileage will read incorrectly.
215/45/18 will be almost perfect on the speedo, with the 225/40/18 your speedo will be slightly off.
Current: E46 ZHP
KILLA CAM
Postby STYLSH » Sat Jun 05, 2010 7:56 pm
I've got those on my car. I'm running 225/45/18 Re001s atm. They make the speedo go out by 1.1% too slow as my stock alloys were 205/60/16s. The fronts will be fine but with the rears I needed 3mm spaces on it as it rubs on the adjustable collars for my coil overs.
STYLSH
