SolaraGuy.com • View topic - Is it a good idea?
Is it a good idea?
Is it a good idea?
Postby mig0s » Thu Jun 03, 2010 10:34 pm
Hey y'all,
So after a month of having the car, I'm thinking about lowering the car now. I've searched a lot but couldn't seem to find a specific answer...
So I know that y'all suggest to change the struts at the same time than the springs. Some of you changed the spring only and the car becomes more bouncy but it's drivable.Since I'm short on money, I'm thinking about putting Eibach lowering springs but only changing the front struts to KYB. I'm keeping the original rear struts since there's rarely people in the back of my car. Does it sound safe/good?
advices would be appreciated :angel:
mig0s
Re: Is it a good idea?
Postby corlon » Fri Jun 04, 2010 12:01 am
sounds fine. i would budget for strut mounts though. i just replaced the fronts only. did the tokico hp series and eibach spring with new toyota strut mounts.
NiCe
corlon
Postby MisterTedster » Fri Jun 04, 2010 12:01 pm
If your lara has the stock SE shocks (as opposed to the SLE), you'd probably be able to get away with it. If you're lucky, you can re-use those strut mounts. I assume you will want to replace all the struts eventually. Personally, I'd wait to save up and just do all of the struts at once when I have the money since it'll be cheaper to do the labor once in the rear instead of twice.
02 SE V6
MisterTedster
Postby mig0s » Fri Jun 04, 2010 8:36 pm
well the thing is for the front struts they are not that hard I can do them by myself...
And Corlon do you mean to replace strut mounts by OEM ones?
So after all it's OK to keep the rear OEM struts with lowering springs?
mig0s
Postby KILLA CAM » Fri Jun 04, 2010 10:59 pm
Don't be a brokedick, and keep saving until you can afford to buy new springs, new struts, and new mounts. It will be worth it, just need patience. If you haven't added a rear sway bar yet, do that also.
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby mig0s » Sun Jun 06, 2010 1:36 pm
Hmmm... is it OK tough if I only replace the front struts to KYB and keep the rear OEM struts? Any more advices? Thanks.
mig0s
Postby KILLA CAM » Sun Jun 06, 2010 9:50 pm
mig0s wrote:Hmmm... is it OK tough if I only replace the front struts to KYB and keep the rear OEM struts? Any more advices? Thanks.
No, do it the right way, and get a complete set. Here you go bro, free shipping: http://cgi.ebay.com/ebaymotors/KYB-4-GR ... ccessories
Current: E46 ZHP
KILLA CAM
Postby ThatVietGuy » Sun Jun 06, 2010 10:02 pm
KILLA CAM wrote:Don't be a brokedick, and keep saving until you can afford to buy new springs, new struts, and new mounts. It will be worth it, just need patience. If you haven't added a rear sway bar yet, do that also.
Seconded.
You'll appreciate the savings in time and money in the end.
ThatVietGuy
Users browsing this forum: Google [Bot] and 24 guests
