SolaraGuy.com • View topic - Need input on 18x8.5 wheels/tire fitment +45 offset
Postby mig0s » Tue Jun 08, 2010 8:18 pm
What's up y'all,
I've been checking on rims everyday for like 2 weeks, I found some 18 inches (coincidentally also on a Solara) that I will go check and probably buy on thursday:
http://montreal.kijiji.ca/c-autos-et-ve ... 208714831#
They are 18x8.5 with 225/40/18 tires. I know they are wide and the guy doesn't know the offset but told me that he put 5mm spacers so they won't rub on his solara. I am not lowered and technically if I put 5mm spacers they will fit too. But I plan to lower the car soon. So if I'm lowered, what setup do I need (which spacers? camber? fender roll?) ?
Update: Offset +45
Thanks y'all
mig0s
Re: Need input on 18x8.5 wheels/tire fitment
Postby KILLA CAM » Tue Jun 08, 2010 8:23 pm
Tell him to measure the offset so we know what we are dealing with and then we can help you...
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby TheMack » Wed Jun 09, 2010 2:38 pm
just out of curiosity....how does one measure the offset?
TheMack
Postby ThatVietGuy » Wed Jun 09, 2010 4:58 pm
ThatVietGuy
Postby Mole » Wed Jun 09, 2010 6:26 pm
sounds like +40 offset
Postby mig0s » Wed Jun 09, 2010 8:49 pm
I guess the offset is +45 according to Fast Wheels website, since it's either +45 or +38
http://www.fastwheels.ca/component/page ... Itemid,62/
So what's do I do? Fender roll? Camber? Spacers?
Thanks
mig0s
Re: Need input on 18x8.5 wheels/tire fitment +45 offset
Postby ToyoSolV6 » Thu Jun 10, 2010 11:02 am
ive rocked +45 offset on my previous wheels, and yeah when you lower the car you will need to run at least 5mm spacers, and definitely roll your fenders.
Postby mig0s » Thu Jun 10, 2010 2:43 pm
ToyoSolV6 wrote:ive rocked +45 offset on my previous wheels, and yeah when you lower the car you will need to run at least 5mm spacers, and definitely roll your fenders.
hey thank you very much for the help! what was the width of your wheels? 8.5 like the rims im checking on? and 5mm spacers in both the front and the rear? thanks!
mig0s
Postby ToyoSolV6 » Thu Jun 10, 2010 3:36 pm
well thats the problem my old wheels were only 7.5 but they were a +45 offset maybe with your set up since the wheels are 8.5 you will probably have to run a bigger spacer but you might run the risk of your lug nuts not grabbing the way they are supposed to.
Either way give it a shot i would say a 5mm spacer would be ok
and you shouldnt need it in the front, just the rear.
