SolaraGuy.com • View topic - Universal Spacers
Universal Spacers
Universal Spacers
Postby hari-bhari » Thu Jun 17, 2010 4:54 pm
About to pull the trigger on some 19x8.5" wheels +38, running 225/35/19 tires. I'll need 5mm spacers in the rear (or maybe 8mm, thoughts?). Anyways, I was looking at spacers and it doesn't seem like I'll need extended lugs for just 5-8mm. My question is, will I need to buy a spacer with a hub on it so the wheel has something to sit on? Is 5mm thick enough to obscure the stock hub? I still want to use hubcentric rings with the wheels so they sit properly centered on my hub, but I don't know if the spacer is going to get in the way of this. Any thoughts?
hari-bhari
Re: Universal Spacers
Postby Midias » Thu Jun 17, 2010 7:53 pm
I might have some ichbachi spacers around 5mm with the correct size hub. I will let them go cheap let me look.
Postby ---CAMRAZY--- » Thu Jun 17, 2010 8:23 pm
If you do the universal cheap ones, do not go over 5mm on the oem studs.
Postby hari-bhari » Fri Jun 18, 2010 8:49 am
Thanks for the replies. I'll def ve interested in the ichiba ones. I think I'll bite the bullet and pay for the ichiba ones because they are hub centric and won't wobble. will I still be able to use the hubcentric rings with the wheels? I'm not sure if being hubcentric is only important for the fronts or not? So I guess final question is since this for the rears only, do I go universal for $20 or pay $50 for hubcentric?
hari-bhari
Postby Midias » Fri Jun 18, 2010 9:00 am
hari-bhari wrote:Thanks for the replies. I'll def ve interested in the ichiba ones. I think I'll bite the bullet and pay for the ichiba ones because they are hub centric and won't wobble. will I still be able to use the hubcentric rings with the wheels? I'm not sure if being hubcentric is only important for the fronts or not? So I guess final question is since this for the rears only, do I go universal for $20 or pay $50 for hubcentric?
Let me look when I get home if I still have them (moved recently) I can do better than 50 for 2, 5mm ichiba spacers that are already hub centric.
Postby hari-bhari » Sun Jun 20, 2010 8:45 pm
do you have them?
hari-bhari
Postby Midias » Mon Jun 21, 2010 4:11 am
hari-bhari wrote:do you have them?
Sorry man looked all weekend could not find them I can check the parents house later if you are not in a hurry.
