SolaraGuy.com • View topic - ATTN: All Speed Source Shifter Cable Bushing Kit Owners!
Postby KILLA CAM » Mon Jul 05, 2010 7:12 pm
Make sure you use plenty of lube on your bushings!!!
Or, you might end up like me and have a broken cable! :(
I dropped $167 for a replacement cable at the Toyota dealership. That's right, 167 smackaroos for ONE cable!!! :x :x :x
I've spent all day trying to get the bushing off of the pin!! :2gunfire:
And finally, Success! :cheers:
So if you have the solid brass bushings already installed, or you plan to install them, make sure they are lubed up good and well or you might run into the problem that I did and before you know it you're driving along and you're stuck in either 3rd or 4th gear. :-?
Save yourself the hassle!
LUBE UP! :P
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Re: ATTN: All Speed Source Shifter Cable Bushing Kit Owners!
Postby SleeperSolara » Mon Jul 05, 2010 8:12 pm
:o
Dang man.
Postby lemegacool » Fri Jul 09, 2010 8:03 pm
daayyyuuuumm!
thanks for the heads up man! i'm about to do a 5 speed swap and i have these in front of me now...
i planned to put permatex high temp anti-seize compound on them... should that do the trick?
1994 camry v6 5 speed swapped
custom m90 blower in progress
cardomain: http://www.cardomain.com/ride/3872430
lemegacool
Postby ptballer » Sat Jul 10, 2010 3:25 pm
Damn thats crazy. I'm gonna lube mine up asap.
ptballer
Postby TMMK Toy » Tue Jul 13, 2010 5:27 pm
Hmm, wonder if this has anything to do with the issues I sometimes have going between third and fourth? I had attributed it to worn motor mounts before. So this will sound stupid, but where exactly do you lube them and with what? Trying to understand how it caused it to break off where it did for you being a metal bushing and all
TMMK Toy
Postby 02slera » Tue Jul 13, 2010 6:13 pm
lube all moving parts with wd40. lol
...i would just put bearing grease on there, but im no expert.
2002 Solara SLE v6
02slera
