SolaraGuy.com • View topic - Exhaust recommendations - need suggestions
Postby JoeB » Tue Aug 19, 2003 6:46 pm
I have the TRD exhaust and JP Performance headers and Y-Pipe. The rest of my exhaust is stock. I know so little about it, I'm not sure what else there is other than a catalytic converter. Is this a decent setup or do I need to consider anything else? I passed the Maryland State emmisions test with this setup and would like to be able to do that without having to swap parts before the next test. Any suggestions? Thanks -JoeB
JoeB
Postby Guest » Tue Aug 19, 2003 6:53 pm
uhhhh.... how can the rest of your exhaust be stock when u have basically upgraded every part of the exhaust
Guest
Postby Mole » Tue Aug 19, 2003 7:20 pm
the sectional Mid pipe.
that is the dinky bottle neck. just go to a shop, get 2.25 pipping done. you should feel less restriction and better exhaust flow.
Postby SC V6 » Tue Aug 19, 2003 9:05 pm
3 inch from JP Performance
SC V6
Postby jisook » Tue Aug 19, 2003 9:46 pm
header wrap is good too...especially if u have ram-air....... then ghetto rig ur own heatshield for ur am intake if u have one already......... shouldnt be too hard for the jp headers.......
jisook
Postby Mole » Wed Aug 20, 2003 1:08 am
Scottv6 wrote:3 inch from JP Performance
depending if he is s/c, he may not need 3'
Postby JoeB » Wed Aug 20, 2003 4:00 am
I do have the Super Charger so I imagine the 3" pipe would be a good addition? If I understand correctly, the more air I take in (blower), the more air I need to exhaust. I have the 2.8" pulley on order to increase to 6 psi boost and an Apexi SAFCii Limited Edition A/F computer. So if I understand correctly, theonly thing left is the mid-section of pipe that is less than 2.25" in diameter and my catalytic converter from the original exhaust. If I replace the mid-section to 3", don't I still need to adapt down to the opening of the catalytic converter? If I have to adapt down, don't I restrict the air-flow anyhow? I want maintain the ability to pass the smog test so I think I need to keep the cat in there?.?. I don't know what the diameter of the TRD exhaust is but I'm pretty sure it is less than 3". It wouldn't help to have the mid-section of pipe larger than the end section would it? Thanks again for the help and suggestions, I'm learning. Sorry I didn't list the mods, see below. -JoeB
Red '99 Solara SLE (V6 AT)
(TRD Stage 3 Performance kit)
TRD Body kit, springs, struts, wheels
TRD front & rear sway bars
TRD Super Charger
TRD Exhaust
JP Performance Headers and Y-Pipe
RMM Intake Kit
6 PSI pulley (next week)
Apexi SAFCii Limited Edition (next week)
Clear corners
PIAA H4 Super Plasma GT-X H4 60/55w=135/125w headlights
35% Window tint (legal restriction in MD)
Stripped all badging
Xerd CAI if I'm convinced of the solution.
Open to suggestions too :wink:
JoeB
Postby Mole » Wed Aug 20, 2003 7:34 am
if you take the car to the shop, have them install a high-flow cat, and 2.5 or 3' pipping. if you get 3' pipping, then your TRD muffler will be the bottle neck, since those are 2.25 pipping.
Postby SC V6 » Wed Aug 20, 2003 8:55 am
Get the real exhaust, and get the 3 in exhaust from JP
SC V6
Postby Mole » Wed Aug 20, 2003 9:49 am
Scottv6 wrote:Get the real exhaust, and get the 3 in exhaust from JP
so you're asking him to get 2 exhausts???
Postby JoeB » Wed Aug 20, 2003 10:09 am
OK, I sure feel stupid :oops: . I didn't even realize what a great thing I have. I actually have a high-flow cat on my JPP Y-Pipe AND it passed the MD state emissions test! So, my exhaust is 3" all the way back to the mid-section of pipe where I guess it goes down to stock 2", then the TRD exhaust which I believe is 2.25". Just plain common sense says that if I hit a 2" section of pipe along the way, I'm seriously restricting the engines ability to exhaust air. I've got an RMM intake and a S/C with a 6psi pulley (coming next week) to get the air in but that does limited good if the engine can't exhaust the air that comes in. The backpressure from the constricted exhaust will restrict the amount of air that can come in. If I learned correctly from you guys...
Well the SECOND I figured this out, I placed an order for the 3" exhaust from JPP! Those guys do GREAT work. I'm very impressed with the headers and Y-Pipe I got from them. Thanks for the help and being patient. -JoeB
JoeB
Postby JoeB » Wed Aug 20, 2003 10:14 am
TRDMole177, you're right, 2 exhausts. I really liked the TRD exhaust too, it had a nice sound and was an easy mod when I was just getting started. Looks like I might have a TRD exhaust that I'd let go cheap soon. It just makes sense. -JoeB
JoeB
Postby SC V6 » Wed Aug 20, 2003 11:15 am
In my garage I have the Greddy catback system, and my entire stock setup.. from thje engine back... as well as Jp's entire exhaust system on my car... and I think the Jp is (in my opinion) the best, as well as unbeatable...
later
Scott
SC V6
Postby happy_aggies » Wed Aug 20, 2003 12:50 pm
Care to part the Greddy Scott?
happy_aggies
Postby Mole » Thu Aug 21, 2003 1:05 am
awww, whats wrong arief? getting bored of the JIC??
Users browsing this forum: Google [Bot] and 45 guests
