SolaraGuy.com • View topic - How would this come loose
Postby ToyoSolV6 » Fri Sep 10, 2010 9:27 am
So I kept hearing this metal hitting metal sound coming from my engine bay for the last week and when i would shift hard into any gear i would hear something hit pretty bad, i looked in my engine bay today and found that the two bolts holding the torque rod bracket are gone its like someone went in there and took them out because the bracket is not broken both bolts are just out.
heres a pic i took this morning:
Re: How would this come loose
Postby ftw » Fri Sep 10, 2010 10:10 am
Maybe they just backed out. Did you use some loctite and torque them down?
New Daily: 2005 Corolla XRS
SOLD: DWP 1999 SE V6| Eibach/Tokico| Super Pro Dogbone Bushings, FSB Bushings| Energy Suspension Front Control Arm Bushings| Injen Intake
ftw
Postby KILLA CAM » Fri Sep 10, 2010 11:08 am
Supercharged @ 5.5psi
288whp 270tq. :bird:
There's your answer. Make sure you use Gabe's reinforced bracket, go to a junkyard and get some bolts or go to your Toyota dealer and get some new bolts, use some locktite. Then make sure your rear headers/egr valve isn't damaged due to engine flexing... <--- This happened to me when my stock bracket initially broke.
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby ftw » Fri Sep 10, 2010 12:26 pm
It already looks like he's using a reinforced bracket.
ftw
Postby ToyoSolV6 » Fri Sep 10, 2010 3:26 pm
yep already have the reinforced bracket, ill def. check that out tho, hopefully nothing else is damaged.
Postby amabsolute » Fri Sep 10, 2010 7:15 pm
ftw wrote:Maybe they just backed out. Did you use some loctite and torque them down?
you should lock tit e everything, vibrations are a bitch
IMG]http://i458.photobucket.com/albums/qq306/amabsolute1/crap-1.jpg[/IMG]
amabsolute
Postby SleeperSolara » Sun Sep 12, 2010 11:48 am
Yeah they could've back out like everyone else has said.
When i was changin' my oil the previous time, i noticed the big bolt on the bottom of the torque rod was backin' out on me, and i just retightened and torqued it down as much as i could.
Postby ToyoSolV6 » Sun Sep 12, 2010 2:44 pm
well i boought the bolts and i bought some lock washers and i put lock tite on all bolts hopefully it wont happen again now the car feels amazing again :)
Postby SirThomas88 » Tue Sep 14, 2010 5:21 pm
ToyoSolV6 wrote:well i boought the bolts and i bought some lock washers and i put lock tite on all bolts hopefully it wont happen again now the car feels amazing again :)
i'd be surprised if it came loose again after that haha.
SirThomas88
