SolaraGuy.com • View topic - 16 inch step up
16 inch step up
16 inch step up
Postby S.Z.-Alpha » Sun Sep 26, 2010 11:49 pm
I'm planning to upgrade into a lighter wheels but not plus sizing. I just want to make the wheels look better and also lighter without compromising comfort. 16s arent that responsive as hell but they're damn comfortable on the highway.
This one's a Sport Edition CD (close the style i'm looking for and lighter than the one i wanted XD)
Specs are:
Offset: 38mm
Backspacing: "
Bolt Pattern: 5-114
Rec. Tire Size: 205/60-16
Weight: 19.8lbs.
ASA AR1 it's called
Specs are:
Offset: 40mm
Backspacing: 5.63"
Bolt Pattern: 5-114
Weight: 18.1lbs.
I'm concerned about the larger widths of two wheels. Are these wheels good and capatible without(or little) modification?
2000 Toyota Solara a.k.a "Goldie" SLE V6 //PARTS: TRD Muffler w/ Stock pipes, K&N filter, Tokico Blue Shocks w/ Stock Springs, Kenwood H/U with x4 JVC speakers(250x2 Front and 290x2 Rear) w/ JL 1000 watt amp.
S.Z.-Alpha
Re: 16 inch step up
Postby S.Z.-Alpha » Thu Sep 30, 2010 8:14 pm
Bump
S.Z.-Alpha
Re: 16 inch step up
Postby yaddadaimsayin » Fri Oct 01, 2010 12:19 am
7 is extra width? I think you're fine.
Re: 16 inch step up
Postby S.Z.-Alpha » Fri Oct 01, 2010 4:34 pm
Really? it's neglegable?
S.Z.-Alpha
Re: 16 inch step up
Postby yaddadaimsayin » Fri Oct 01, 2010 4:45 pm
Re: 16 inch step up
Postby S.Z.-Alpha » Wed Oct 13, 2010 10:30 pm
Ah, got it. now the "looks" issue. What do you think is better?
S.Z.-Alpha
Re: 16 inch step up
Postby SleeperSolara » Thu Oct 14, 2010 11:11 am
I like the ASA AR1's.
