SolaraGuy.com • View topic - disable automatic lights
Postby huj2000 » Tue Sep 28, 2010 11:57 am
i want to get hid's and i want to disable to drls and i want to disconnect the sensors so my lights wont automatically turn on when it gets dark i have already found the connection for the drls but im not sure where to disconnect the sensors does anyone know where those connections are
99 solara sle v6 - intake - headers - cat removed
huj2000
Re: disable automatic lights
Postby ThatVietGuy » Tue Sep 28, 2010 12:08 pm
ThatVietGuy
Postby huj2000 » Tue Sep 28, 2010 9:40 pm
i disconnected the cable to disable the drls but i dont want my lights automatically turning on at night so i want to disconnect the light sensors also
huj2000
Postby huj2000 » Tue Sep 28, 2010 9:44 pm
also i have a question about hid's are the bulbs with hi/low beam interchangable with the ones that are just low beam or is a different ballast required
huj2000
Postby mig0s » Tue Sep 28, 2010 10:18 pm
huj2000 wrote:i disconnected the cable to disable the drls but i dont want my lights automatically turning on at night so i want to disconnect the light sensors also
On your passenger side dash there's a round stuff that looks like a space shuttle, pop it up and disconnect it.
mig0s
Postby huj2000 » Wed Sep 29, 2010 8:05 am
thanx im gonna do that today, finally i can pull in the driveway at night and not blind all the neighbors :lol: thanx all
huj2000
Postby solara_kid2000 » Sat Dec 25, 2010 3:53 am
hey i got another hid question so i disabled my DRLs and the sensor but my left hid is brighter than my right its a brand new kit so i dont think thats it anyone kno what i can do to fix this?
solara_kid2000
Postby dinoxor » Sat Dec 25, 2010 2:42 pm
huj2000 wrote:also i have a question about hid's are the bulbs with hi/low beam interchangable with the ones that are just low beam or is a different ballast required
for gen 1's the hi/low uses only one ballast but when you trigger the hi beam switch, it'll move this magnetic strip inside the bulb which will focus and make it seem brighter.
http://www.youtube.com/watch?v=OLGsa36l ... re=related
you can see how it slides and stuff.
But if you just get the low beam ones then when you trigger the hi beam it'll just turn off your low beam thats all.
some advantage with hi/lo (this is my current setup)
you can sorta flash a person behind or ahead of you
focused beam ahead of you for better view of the road.
disadvantages:
hi beam isn't really effective unless you have projectors
hi beam will hot or dead spots unless you spend the day adjusting your headlights.
requires this longass harness that goes from one side to the other side so that it'll get juice to activate the hi beam
whereas the lo beam will just have their own ballast on each side.
hopes this answers your question and help you a bit!
dinoxor
