SolaraGuy.com • View topic - Home Made Intake
Home Made Intake
Home Made Intake
Postby sp3cialed » Fri Oct 01, 2010 11:05 pm
So I was in pep boys today, I want to duplicate this.
viewtopic.php?f=55&t=50107&p=587784#p587784
then there was a thread (I searched!) that said the gen 1 was different located here
viewtopic.php?f=20&t=50290&p=590106&hilit=maf+sensor#p590106
So to clarify. If I remove my resonator and place it on the 6" tubing (drill hole for it) that is the ONLY hole I need correct? The other smaller two sensor holes? are not for gen 1.
sp3cialed
Re: Home Made Intake
Postby sp3cialed » Fri Oct 01, 2010 11:21 pm
sorry not placing the resonator on the tubing, just the air sensor tube?
sp3cialed
Postby SirThomas88 » Fri Oct 01, 2010 11:44 pm
Why do u want to keep your silencer (resonator?)?
You're prolly better off just buying the Injen or OBX brand short ram intake.
As far as how many holes you need for tubing, look under your hood at your stock intake for an easy answer to that question. I believe there is one that you DON'T need at all. Not sure how to describe which one it is.
SirThomas88
Postby sp3cialed » Sat Oct 02, 2010 12:07 am
thanks for the reply, sorry i DO NOT want the resonator, but all it is is getting the MAF extension, and sticking w.e tubes i need back into the intake right? haha. I calculated all the tubing and couplings, turned out to be right around $30 which is nice. CAn't find OBX on ebay anymore.
sp3cialed
