SolaraGuy.com • View topic - Wheels width
Wheels width
Wheels width
Postby S.Z.-Alpha » Fri Oct 22, 2010 10:17 pm
I found some wheels that are sooo deliciously bodacious and i'm wondering if changing the wheels to this size wheel will do some weird(or bad things)
Specs are:
Size: 16x8 (that's 2 inches more from the stock)
Offset: 38mm
Backspacing: unknown
Bolt Pattern: 5-114
Weight: estimated 18~19 lbs..
What will happen if i changed from the stock rims to these using the same existing tires i used on the stock which are 205/60/16s
Will there be sidewall issues because of the wider width? 205mm is already 8.1 inches(i think)
Post any advice please, thanks O_o
2000 Toyota Solara a.k.a "Goldie" SLE V6 //PARTS: TRD Muffler w/ Stock pipes, K&N filter, Tokico Blue Shocks w/ Stock Springs, Kenwood H/U with x4 JVC speakers(250x2 Front and 290x2 Rear) w/ JL 1000 watt amp.
S.Z.-Alpha
Re: Wheels width
Postby 02slera » Sat Oct 23, 2010 8:19 am
i thought offset and backspacing was the same thing...
my rims are 18x8 (i think) and my tires are 225/40/18 (225 being the width), i dont know enough to say whether your tires will work.
beware if lowered there is a good chance you'll have to shave or roll the rear fenders. i rolled mine myself being very careful and patient with a rubber mallet -this is not recommended but is possible.
2002 Solara SLE v6
02slera
Re: Wheels width
Postby S.Z.-Alpha » Sat Oct 23, 2010 3:13 pm
No sweat, mine's not lowered. I live in a town where roads suck so yea
S.Z.-Alpha
Re: Wheels width
Postby Mr_Krispy1183 » Sun Oct 24, 2010 10:40 pm
+38 on an 8" width will require a fender roll when you're lowered, but since you're not, I can't knowingly say.
Re: Wheels width
Postby S.Z.-Alpha » Mon Nov 08, 2010 12:33 pm
Hmm...Thanks. Btw I was looking as BBS RXs on ebay. The seller gave me an update on the weight. they say it's 21 lbs each so no sale X3
S.Z.-Alpha
Re: Wheels width
Postby Mr_Krispy1183 » Mon Nov 08, 2010 10:17 pm
The extra weight shouldn't be a dealbreaker. BBS makes quality wheels, and they would withstand a beating, unlike most cheapo Taiwan/Philippine knockoff brands, that may be cheap and light(er), but at the expense of being made of inferior casts.
Re: Wheels width
Postby S.Z.-Alpha » Tue Nov 09, 2010 6:15 pm
That's harsh man O_o I'm filipino. we dont make the stuff, we get them imported from e_e
Dont put down the pinoys man XD
Oh yea BBS's are legendary. alot of TRD cars have BBS wheels.
S.Z.-Alpha
Re: Wheels width
Postby yaddadaimsayin » Tue Nov 09, 2010 6:29 pm
i think brian is too?
Re: Wheels width
Postby Mr_Krispy1183 » Tue Nov 09, 2010 11:51 pm
I'm Filipino as well, and Rotas still suck ass.
Re: Wheels width
Postby S.Z.-Alpha » Wed Nov 10, 2010 12:12 am
I'm thinking of Voxx wheels right now. Are they good? I particularly like the MG-3. It looks italian.
S.Z.-Alpha
Re: Wheels width
Postby S.Z.-Alpha » Tue Dec 07, 2010 4:56 pm
Scratch that...Voxx wheels suck. I'm back getting those BBS RXs this time however has the proper width on them XD. 16 x 7Js to be exact with 40 mm offset hoohah! less width means less weight right?
S.Z.-Alpha
Re: Wheels width
Postby mig0s » Tue Dec 07, 2010 4:57 pm
what is your suspension setup?
mig0s
Re: Wheels width
Postby S.Z.-Alpha » Tue Dec 07, 2010 5:02 pm
mig0s wrote:what is your suspension setup?
Partly stock. I got Tokico struts in the back. with all stock springs(AND 205/60/16 tires) Having the magnificence of the BBS RXs i'm gonna get, i'd lower them Xp. Wouldnt you?
S.Z.-Alpha
Re: Wheels width
Postby mig0s » Tue Dec 07, 2010 5:13 pm
That's what I'm asking lol because if you have stock suspension, even with the BBS it would not look good. Get the coilovers, don't do the same mistake as me, as buying lowering springs and struts but ends up wanting to be lower... lol. But here in Montreal the roads are so bad, you can't actually be slammed without causing damage do your frame. I'm still a happy man.
Also, I suggest you to get lowered BEFORE getting rims :)
mig0s
Re: Wheels width
Postby S.Z.-Alpha » Tue Dec 07, 2010 5:18 pm
Road's here are the same. I cant lower it cuz i go to the backroads sometime.
S.Z.-Alpha
