SolaraGuy.com • View topic - timing belt/coolant
timing belt/coolant
timing belt/coolant
Postby TheMack » Sat Oct 30, 2010 1:26 am
noticed my timing belt has started to make some noise and was wondering if there is a specific one you guys recommend for any purpose whether it be power gain or any advantage
also i am low on coolant and was wondering if just any 50-50 antifreeze and water would work
TheMack
Re: timing belt/coolant
Postby SleeperSolara » Sat Oct 30, 2010 7:59 am
No power gain wit timin' belt.
Yes you are right about the anitfreeze.
Be sure to use distilled water.
By the way you need to search first before postin' .......
Postby TheMack » Tue Nov 02, 2010 12:57 am
i thought i had red something about only using toyota red or pink or something like that which is why i asked
TheMack
Postby 02slera » Tue Nov 02, 2010 3:30 am
i was thinking the same thing. i also read that you should only use the toyota red coolant, it was somewhere on this forum, sorry dont have time to search for ya, but if it was me, i'd use the red just to be safe.
2002 Solara SLE v6
02slera
Postby GreeKAvaLoN » Tue Nov 02, 2010 6:56 pm
my coolant has been green/brown the past 10 yrs/ 100k miles :D i recommend using toyota stuff though. that's all that going in my new motor.. btw, old motor ran and runs perfect w/ that coolant
GreeKAvaLoN
Postby solara90 » Thu Nov 04, 2010 7:03 pm
i personally would just get some from youtr local toyota dealer, really something i dont wanna skip out on. Its like $26 for a gallon at the dealer, but get the right coolant or risk screwing up your cooling system and spend some big $$$
02 solara 2az
solara90
Postby CamryOnBronze » Mon Nov 08, 2010 9:40 am
Pick up some distilled water as well, since the Toyota coolant needs to be mixed 50/50 with water, according to my friend who is a Toyota Tech. Also do yourself a favor and get the OEM timing belt. Might as well replace the water pump while you are in there, in case you get the belt done and it needs a water pump a month later. Good luck!
Postby kenny6683 » Mon Nov 08, 2010 1:48 pm
dang i think i need to do belt as well. mine also started making a bit of noise.
im thinking of doing this myself but damn its cold out and no garage right now
wonder if i can wait until spring?
anyways as for the coolant... buy one thats premixed and safe to mix for all colors. around $20 sometimes. its ok to mix red with green as long as its one of these types
kenny6683
Postby TheMack » Mon Nov 08, 2010 5:15 pm
i appreciate all the advice fellas, im gonna get an OEM belt and get teh water pump replaced as suggested just in case, and ill take kenny's advice for the predilluted mix, thanks again, btw how much should i be looking to spend on the belt and water pump so i dont get screwed?
TheMack
Postby 02slera » Tue Nov 09, 2010 4:46 am
well to each there own, i personally dont want my coolant looking like dookie, so i just use red. and i would price the belts and pump at autozone or advance auto even if your not buying there just to get an idea of prices.
2002 Solara SLE v6
02slera
Postby TheMack » Tue Nov 09, 2010 2:31 pm
ok, thanks
TheMack
