SolaraGuy.com • View topic - Big Brake Kit Opinions
Postby EricSol » Mon Aug 25, 2003 5:21 pm
I started on a big brake upgrade on my car and would anybody be intrested in OEM 13" rotors with a caliper relocation kit for very inexpensive. I'm talking about $140 for CNC machined aluminum brakets with all the hardware neccesary to move your calipers to accept 13" rotors. I priced the Rotors and Raybestos start at $80 all the way up to Cross and Slotted Brembos for $300 each. You could wind up spending as little as $300 total. I took my spindels and rotors to the machine shop so I need an idea of how many to make.
These are for Gen4/Solara.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby SC V6 » Mon Aug 25, 2003 6:23 pm
Im interested... I might need to get some money together.. sounds like a good idea to me.. whats going on w the motor mounts??? Im still thinkin into those
later
Scott
SC V6
Postby boneezy » Mon Aug 25, 2003 6:47 pm
Eric is GOD of all Solaras... every1 must bow in his reverence.... haha.. jk... thanks for everything eric.... keep em coming!
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby EricSol » Mon Aug 25, 2003 7:00 pm
Scottv6 wrote:Im interested... I might need to get some money together.. sounds like a good idea to me.. whats going on w the motor mounts??? Im still thinkin into those
later
Scott
I just installed a Energy made prototype and am sending another to Carlo to test. I think they might be to soft and they only pour what I want once in a blue moon so I'm working on it but it might take a while.
The Big Brake kit should be ready in a month, I just need to find out how many to make. The more I can make the cheaper the price.
1999 Solara 296 whp
EricSol
Postby JoeB » Mon Aug 25, 2003 8:26 pm
Eric, I know NOTHING about brakes. I put everything into "GO" and nothing into "STOP". Probably not wise. Can you explain what you said above in layman's terms? What is it we have stock, what is it we are considering and how good is it? Maybe it'll help others as well but they didn't want to ask. -JoeB
JoeB
Postby EricSol » Mon Aug 25, 2003 8:53 pm
What I said was replace your whimpy 11" rotors with 13" using your stock calipers moved out for the bigger rotors. Like I said depending on the rotors you buy you could have big brakes for $300 total instead of the Brembo kit for for $2k.
JoeB wrote:Eric, I know NOTHING about brakes. I put everything into "GO" and nothing into "STOP". Probably not wise. Can you explain what you said above in layman's terms? What is it we have stock, what is it we are considering and how good is it? Maybe it'll help others as well but they didn't want to ask. -JoeB
1999 Solara 296 whp
EricSol
Postby ICrazyChrisI » Mon Aug 25, 2003 9:03 pm
I'm interested in the brakes. From which car are the 13" rotors comming from?
ICrazyChrisI
Postby Yanks0114 » Mon Aug 25, 2003 9:29 pm
Heres a good way to explain what these can do for your brakes even on stock calipers.
Spin a bike tire...
Now try and stop it by grabbing in the center of the rim,
Then try and stop it by grabbing the actual tire.
The further out you grab, the easier it is to stop. Therefore the larger rotors will increase braking power.
Postby i20solara02i » Mon Aug 25, 2003 10:11 pm
i'll b interested any pics?? when done
richard
i20solara02i
Postby gnaw_divad » Tue Aug 26, 2003 3:05 am
definately interested
gnaw_divad
Postby happy_aggies » Tue Aug 26, 2003 6:51 am
So it's not a full caliper setup?
happy_aggies
Postby chef solara » Tue Aug 26, 2003 6:51 am
Hey Eric,
You can count me in, just tell me when you want my money,
Ourhogan@gate.net
772-521-5292
chef solara
Postby chef solara » Tue Aug 26, 2003 11:54 am
Will you be offering new S.Steel brake lines also? Or will we have to find thoese some where else.
chef solara
Postby EricSol » Tue Aug 26, 2003 4:10 pm
chef solara wrote:Will you be offering new S.Steel brake lines also? Or will we have to find thoese some where else.
Get the goodridges like I have. I might do a caliper upgrade in the future but its expensive, how many people bought the $2k Brembo kit? My cost on 4 piston calipers is like $400 each, you add a $300 Brembo rotor and the matching steel line and the custom made CNC brakets to make it bolt on and you quicky get to $1k a side and like I said there already is a $2k kit on the market.
I like the idea of $140 brakets that you can get your own rotors for. I personally found Raybestos for $80 each, that puts the total cost at $300.
1999 Solara 296 whp
EricSol
Postby EricSol - Guest » Tue Aug 26, 2003 4:20 pm
EricSol - Guest
