SolaraGuy.com • View topic - any gen 1.5'ers use these clear corners? Do they even fit??
Postby xavier » Fri Nov 19, 2010 1:30 pm
So I found these on the bay http://cgi.ebay.com/ebaymotors/02-03-TO ... 4065wt_939
Anyone with experience with em. Do they really fit the gen 1.5 or is it just an uninformed seller mis labeling gen 1 corner?
xavier
Re: any gen 1.5'ers use these clear corners? Do they even fi
Postby SleeperSolara » Fri Nov 19, 2010 2:01 pm
Well i put in 2000 Solara, and it says it doesn't fit.
But the picture shows it as Gen 1 corner lights.
Does the Gen 1.5 corners fit on the Gen 1 ??
Cause it looks like it would.....
Postby xavier » Fri Nov 19, 2010 2:08 pm
No, the gen 1.5 corners definitely do not fit the gen 1. I know that they are different but I cant eyeball the difference. So if you are certain that these are indeed the gen 1, then I'm outta luck.
Thanks
xavier
Postby kenny6683 » Fri Nov 19, 2010 4:29 pm
The image seems to be gen 1 corners but the
difference is, the area farthest from headlights on the corners are different.
Gen 1 is more rounded and gen 2 is a bit more skinnier/ pointier
you may not be able to tell from this ebay listing that easy though.
if they do not fit your gen 1 then save them and buy gen 1.5 fenders to go with it : )
kenny6683
Postby xavier » Fri Nov 19, 2010 7:04 pm
I already have gen 1.5 fender as my solara is a 2002. But I have a crack in one of my black corners which is filling with water so I need a replacement.
xavier
Postby SleeperSolara » Sat Nov 20, 2010 12:17 am
Just got a message from the seller, it only fits 2002 to 2003 Solara's......
Postby xavier » Sat Nov 20, 2010 6:20 am
Really?? Hmmm that makes me think its legit as I remember the mis informed products were listed as fitting 99-03. Maybe Ill give give em a shot. Thanks for the info!
xavier
Postby SleeperSolara » Sat Nov 20, 2010 12:27 pm
xavier wrote:Really?? Hmmm that makes me think its legit as I remember the mis informed products were listed as fitting 99-03. Maybe Ill give give em a shot. Thanks for the info!
Yeah.
You should get a pair and see if they fit your car, if they don't let me know.
