SolaraGuy.com • View topic - Thinking of going with the ACT clutch (TY4-HDG6)
Postby SirThomas88 » Tue Dec 14, 2010 3:01 am
So I've been doing some reading around on SolaraGuy, trying to decide what clutch to get. the Centerforce Dual Friction for the Scion tC came personally recommended. I should be doing my 5 speed swap sometime in March.
Browsing the ACT website, I think I found the clutch that will fit my needs perfectly. It's their TY4-HDG6 model (Heavy Duty Pressure Plate, Spring Centered 6-Pad Disk). It's rated to handle up to 499 torque and goes for a pricey $583 on their website.
http://www2.advancedclutch.com/products/clutchkits.aspx?prod_id=6385#6385
In the notes it says it's recommended for road racing and "high power Street," and says the clutch pressure should feel stock to moderate and that it should be quiet and somewhat smooth. Those are important to me because it's my daily driver.
I'm at 5.5 psi and will be bumping up to 6psi, maybe even 7psi with a 3mz hybrid swap (eventually) so I think the clutch being able to handle 499 torque sounds like it's right in my range.
If you have any suggestions, please do let me know what you think!
SirThomas88
Re: Thinking of going with the ACT clutch (TY4-HDG6)
Postby SolaraPete » Thu Dec 16, 2010 8:06 am
I just installed this clutch a few months ago. Re-machined the stock flywheel and used a new OEM throwout/release bearing. I'd say its a bit chattery, and i'd describe the engagement as midly harsh. Took a few weeks to get used to the feel, and now i can engage it a lot smoother during normal driving. Make no mistake, this IS a performance clutch. Dont expect it to feel/sound like your OEM - thats not the reason to buy a 6-puck. Daily driving is no problem; thick traffic (creeping fwd in 1st gear then stopping) is not fun, but certainly not bad enough to wish i never bought it. Its absolutely great at the drag strip! Im currently only at 4psi, and it can def take way more than what im throwing at it!
SolaraPete
Postby SirThomas88 » Fri Dec 17, 2010 8:38 pm
SolaraPete wrote:I just installed this clutch a few months ago. Re-machined the stock flywheel and used a new OEM throwout/release bearing. I'd say its a bit chattery, and i'd describe the engagement as midly harsh. Took a few weeks to get used to the feel, and now i can engage it a lot smoother during normal driving. Make no mistake, this IS a performance clutch. Dont expect it to feel/sound like your OEM - thats not the reason to buy a 6-puck. Daily driving is no problem; thick traffic (creeping fwd in 1st gear then stopping) is not fun, but certainly not bad enough to wish i never bought it. Its absolutely great at the drag strip! Im currently only at 4psi, and it can def take way more than what im throwing at it!
that's great to know. thanks dude. yeah this will be the car i learn to drive manual on so i hope it goes well and im happy with the choice. i dont even know what exactly "chatter" is or sounds like!
i did practice driving manual for like an hour with my friend's chrysler sebring. but that's about it.
SirThomas88
Postby SirThomas88 » Mon Dec 20, 2010 4:28 am
Anyone have any suggestions on a clutch comparable (possibly more affordable as well) to the TY4-HDG6 mentioned above?
SirThomas88
Postby cartang » Mon Dec 20, 2010 8:41 am
I installed the Exedy stage 1/ Fidanza Flywheel in Oct 2010 , works great . ( If I remember the spec for Exedy 1 , 290/320 HP . :)
[IMG]http://i275.photobucket.com/albums/jj307/cartang1/007-2-1.jpg[/IMG]
Camry 99, 5sp manual, SC,CPE intake,OBX headers, Jim's fuel system,Walbro pump,Greddy exhaust,Exedy 1 clutch,Fidanza flyweel.
Camry 07, V6,TRD cat back,Fujita CAI, GS 430 rims
cartang
Postby SolaraPete » Wed Dec 22, 2010 9:25 am
Several people on here have had good things to say about the Clutchmasters set up. Hopefully someone that has one can chime in with specific feedback and pricing info...
SolaraPete
