SolaraGuy.com • View topic - bags or cyclender
bags or cyclender
bags or cyclender
Postby BASolara99 » Thu Aug 28, 2003 7:07 pm
i know i have asked this before but i am wondering if you know how hard it would be to bag my solara or put air cyclenders on it thanks alot Branodn
BASolara99
Postby Flipside909 » Thu Aug 28, 2003 7:12 pm
What's a cyclender? Paper or plastic? :roll:
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby indiglosolara » Thu Aug 28, 2003 7:29 pm
do you mean cylinders like hydraulics, Air bags as in Air ride like those DUBer's.
I would not recommend those on the solara. They can really damage the frame of the car.
But to answer your question: if you bring it to the right shop to do install its not too hard with also the right setup.
kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Jackass-Jeff » Thu Aug 28, 2003 10:48 pm
bags are dangerous. =x
1GR-FE ftw!
Jackass-Jeff
Postby BASolara99 » Fri Aug 29, 2003 9:39 am
Sorry i ment cylinders but as alwasy. Flipside always has to get his 2 cents in no matter what , but i heard that it want hurt nuttin as long as you do it right. I am just worried about the struts if they will hold up.
Thanks Brandon
BASolara99
Postby Guest » Fri Aug 29, 2003 10:25 am
i said the same thing to myself...i would of put my 2 cents in too... learn how to type/spell man....
Cyclender (?)
Guest
Postby boneezy » Fri Aug 29, 2003 10:26 am
Cyclender (?)
whoops that was me...
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby Jackass-Jeff » Fri Aug 29, 2003 11:24 am
If you do go w/ Cyl., the aftermarket struts should hold up BUT may need to be replaced a lot sooner than expected. Good luck =x
1GR-FE ftw!
Jackass-Jeff
