SolaraGuy.com • View topic - Independant Foglights Help Plz
Postby Nemesis85 » Mon Jan 24, 2011 11:52 pm
Alright, before I start. Yes I have used the search function lol. And I have the DIY saved in my favorites, however im not interested in splicing wires and such. A thought has occured to me tho. So the Headlight adapter for the Gen 1 Lara looks as follows | _ | one being the low beams, one being the high beams and one being the negative/ground i believe (plz correct me if im wrong) Second part is, I have HID's installed on my car (low beam only) So I was curious if I plugged the HID's into the Highbeam plug instead of the low beam plug (as long as voltage and whatnot doesn't differ between the low and high beams) Curios if that would work. As I was typing this, i did realize that although i would have fogs on with no headlights, turning on the highbeams to actually turn on my HIDs, would disable the fogs. So I could ONLY have fogs on without headhlights on as well. Still curious if my thoughts are accurate and if this would work =)
Nemesis85
