SolaraGuy.com • View topic - Gen 1 Projector Retrofit
Postby I113GAL » Tue Jan 25, 2011 9:06 pm
Whats up yall
Ive been thinking for a while about doing some projector retros on the 99 V6 I just bought.
Ive never attempted a retrofit before but I feel pretty comfortable tearin my headlights out and tryin this. :drinking:
I was thinkin about this setup
-Morimoto D2S (I heard they were pretty easy to work with).
-McCulloch 5000k Hids i found for about $100
-And a E46 shroud.
I thought about about painting the reflector and whole housing black or just the shroud.
Whats everyones opinion or advice? Like I said im a big nub to all of this.
I113GAL
Re: Gen 1 Projector Retrofit
Postby SleeperSolara » Thu Jan 27, 2011 12:58 am
Doesn't sounds too bad man.
I would suggest gettin' some real D2S bulbs and Lexus denso ballasts.
The E46 shrouds would look nice, but you would need to cover the sides little i think to make it look clean.
Check out some vacuum formin' stuff, that will cover everythin'.
Also let me know if you need some E46 shrouds.
I have the replica ones.
Postby I113GAL » Thu Jan 27, 2011 10:00 am
Yea im going to look for some better HIDS. I was just trying to save a little $$. Someone Said the Morimoto MH1 Would be a better fit? What do you think? Let me get back to you on those shrouds how much u thinkn on those puppies?
[EDIT] Just checked out those denso ballasts and damn are they pricey! What would be your cheaper alternative?
I113GAL
Postby hskrsolara » Fri Jan 28, 2011 1:37 am
SleeperSolara wrote:Doesn't sounds too bad man.
did you ever get your retro done? any pics?
hskrsolara
Postby I113GAL » Fri Jan 28, 2011 8:29 am
Not yet I'm still waiting for some more suggestions on what I shuld buy. I'm thinkin he whole mini d2s setup. I'll keep hall posted. Again any advice is appreciated.
I113GAL
Postby SleeperSolara » Mon Jan 31, 2011 10:06 pm
I113GAL wrote:Yea im going to look for some better HIDS. I was just trying to save a little $$. Someone Said the Morimoto MH1 Would be a better fit? What do you think? Let me get back to you on those shrouds how much u thinkn on those puppies?
Well i was thinkin' maybe $40 + shippin'??
[quote="hskrsolara"did you ever get your retro done? any pics?[/quote]
I have about 90% done, just waitin' for some HIPS sheet to get to my house to vacuum a shroud.
Was rollin' wit the new HID's for about a week and a half, and a hella big improvement. :D
Modded the projector somewhat, need to get some ZKW-R lens.
Postby I113GAL » Tue Feb 01, 2011 8:26 am
Well the retro is on the back burner now my gf talked me into sum rims instead. So I guess its gnna b another month b 4 I start ordering parts.
I113GAL
Postby charley240sx » Wed Feb 02, 2011 8:07 pm
do your research before jumping it. its not really that hard, but its not easy either. mounting and fitting is a PITA, and i honestly dont think i would every do a retro.
some very nice projectors:
sc430
s2k
ls430(wide beam, probably wont fit though)
tsx with clear lenses
tl with clear lenses
those are the most popular from what ive seen.
goodluck
Charley
charley240sx
Postby I113GAL » Sat Apr 23, 2011 2:43 pm
***UPDATED***
Just got the projectors in. Went with the morimoto mini h1 projectors with mini gatling shrouds. Im going to try to fit some p1 projectors in there too for the drl's for a quad setup. Painted the oem headlights completely black, with 70mm ccfl on the shrouds. Took quite a bit of time but shes almost finished! :morning: Heres a few pics.
I113GAL
Postby SleeperSolara » Sat Apr 23, 2011 10:19 pm
Oh snaps!!!!!
Looks pretty good man.
Postby I113GAL » Sat Apr 23, 2011 11:18 pm
:P thanks! Im pretty happy with the way it turned out. Took me a few days, 3 ccfl rings, and a ton of redbull. Ill post some more pics when I get the replacement ccfl's. Now just have to redo the fogs :drinking:
I113GAL
Postby DSM_Lara » Sun Apr 24, 2011 1:42 am
Nice so far I like. BTW I don't think any of us saw your car before looking good. Also planning to use LED for the fogs????.
DSM_Lara
Postby DaZanY4002 » Sun Apr 24, 2011 3:22 am
Looks better than pretty good. :sweet: That's sweeter than diabetes.
DaZanY4002
Postby I113GAL » Sun Apr 24, 2011 8:15 am
Yeah I think I am going to go with some leds in the fogs too probablly some white ones. Yours look pretty pimpin, Im just wondering if the lenses will be clear enough if i sand both sides down a little. Btw is that a renova DaZan looks fn cleeeen.
I113GAL
Postby SleeperSolara » Sun Apr 24, 2011 10:14 am
Here's where i'm at so far.....
Distance shot
