SolaraGuy.com • View topic - ENGINE SWAP
ENGINE SWAP
ENGINE SWAP
Postby njzghetofabolous » Fri Aug 29, 2003 10:46 am
hey guys, im new to this forum. I have a 99 solara SE. Its an automatic 4 banger. I was doing some research into doing an engine swap from my 4 cylinder to the 2001 6 cylinder. I wanted to know what parts i can use from my 4 cylinder and what parts i would need to purchase to make the 6 cylinder fit. Any helpful feedback would be greatly appreciated.
Thanks
njzghetofabolous
Postby Ragtop George » Fri Aug 29, 2003 10:50 am
I'm no expert, but the prevailing consensus is that it is much more practical to buy a 6 cyl car to start with rather than trying to convert a 4 cylinder. There are a lot of differences besides the engine, such as transmission, computer, brakes, wheels, suspension, etc.
George
2002 Solara Convertible Automatic
TRD Supercharger, 6 PSI pulley
Apexi WS exhaust, custom Y pipe
TRD RSB on "track" setting
Ragtop George
Postby njzghetofabolous » Fri Aug 29, 2003 10:57 am
well, i dont think i would need to change the wheels, brakes, or suspension...cuz all those are already aftermarket. And i dont have money to buy a new car because i already started working on this solara. + I like the fact that not many people modify this car in my area. So this car is a keeper.
njzghetofabolous
Postby Ragtop George » Fri Aug 29, 2003 11:04 am
Well, if you are bound and determined to do it, then find a donor car and compare the parts. That is always the easiest and most practical way.
George
Ragtop George
Postby njzghetofabolous » Fri Aug 29, 2003 11:10 am
im only willing to do the swap for the v6 so i have the option of getting the TRD supercharger. Unless someone can fill me in on some info for a turbo on my 4banger, then i wouldn;'t have to go throught the hassle.
njzghetofabolous
Postby Jackass-Jeff » Fri Aug 29, 2003 11:16 am
There actual is a turbo kit for the 99-01 4 banger.
http://www.rippmods.com/products/produc ... =Toyota+I4
Yea... they didn't list the engine code, but it's for the 5S-FE 2.2 L Inline 4
A V6 swap is VERY impractical because it'd cost less to sell yours and just buy a V6 Solara.
You'd need the engine, the transmission, the ECU, the new mounts, you'd have to tear out everything under the hood and re-arrange it using the V6 parts (they used differently shaped things so the engine fits. If you look under the hood, your engine has tons of room left over while the V6 is pretty damn cramped). I'm sure there are a few other things you'd need, but I don't remember... If you're going to swap engines, you may as well swap to the new V6 (3MZ-FE) in the new Solara since it's the same as the old... just slightly larger. It uses the same mounts as the 1MZ and the Supercharger (I spoke to a Toyota Parts guy at the dealer) should be here within a year.
1GR-FE ftw!
Jackass-Jeff
Postby Jai_Jai_Binks » Fri Aug 29, 2003 11:23 am
xravexboix wrote:There actual is a turbo kit for the 99-01 4 banger.
:iamwithstupid: <--- Wish we had this smilie! (HINT to mods...cus i don't want to go and find it and host it..blah blah).
Anyhow, the 5s turbo has been around for a while -
It would cost you more to swap out the engine than for you to take a loss on your 4 banger and buy a v6...the money could be well spent on other goodies! (if your wanting to swap things around..and are itching to spend...then i'd much rather put a 3s motor)
Also: use the search button, i'm sure we've advised against this earlier as well... :roll:
Postby DavPak » Fri Aug 29, 2003 12:08 pm
xravexboix wrote:A V6 swap is VERY impractical because it'd cost less to sell yours and just buy a V6 Solara.
i'm on that bandwagon as well.
as long as you're trading in the i4 and getting a V6, do yourself another favor and get a manual trans.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Jackass-Jeff » Fri Aug 29, 2003 4:10 pm
huh? implying I'm stupid? I'm lost lol =x
btw, by actual, i meant actually... too lazy to edit
1GR-FE ftw!
Jackass-Jeff
Postby njzghetofabolous » Fri Aug 29, 2003 8:12 pm
thanks alot for your response guys.. It really helped alot. I was thinking of getting a brand new replacement engine for my 1999 solara...I have the i4 and since im nearing 300,000 miles, i wanted to know if i purchased a new i4 engine from Toyota, would there be any complications installing it?
Another question.
---> xravexboix <----
the turbo kit you referred me too, would you consider it a reliabe turbo or will i end up with a lousy product that will blow my engine?
Thanks
njzghetofabolous
Postby Turbosolara » Fri Aug 29, 2003 8:16 pm
To swap you will need a 1MZFE motor with header and y pipe, transmission, v6 motor mounts, new radiator pipes, new radiator, rear disc brake assembly, drive shaft, v6 ECU, v6 harness (completely) and there might be more stuffs. at camryclub.org there is a guy complete a swap into a 92 celica.
but in my opinion its not worth the headache, just trade it in for a v6 or force induction it
Postby njzghetofabolous » Fri Aug 29, 2003 9:16 pm
ULTRASLOWSOLARA... what type of forced induction system are you using.... What Brand ?
njzghetofabolous
Postby Turbosolara » Sat Aug 30, 2003 1:46 am
Custom make from turbo-performance. I have turbo set up, please read my signature
Postby WTF?? » Fri Sep 19, 2003 2:21 pm
http://cgi.msn.ebay.com/ebaymotors/ws/e ... 2433464827
Welps... heres an engine if someones up for it
Good luck!! lol
Retired... its been fun Image
WTF??
Postby HKSV6SLE » Fri Sep 19, 2003 8:32 pm
just get a new solara....only people who race their cars will have the time or the funds do so such a swap....and i don't think i've ever seen a 4-6 engine swap in a toyota....i've seen supras running mr-2 engines..but that's about it.....
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
