SolaraGuy.com • View topic - Gen 1 front lips
Gen 1 front lips
Gen 1 front lips
Postby Dr.Jenkins » Mon Feb 21, 2011 9:50 am
After purchasing a set of kaminari kits pcs., has anyone successfully painted the kit with matching paint without professional serviecs but purely DIY at home with store bought paint? Second question if so was the paint say DWP?
Dr.Jenkins
Re: Gen 1 front lips
Postby 99BlackSandv6 » Mon Feb 21, 2011 1:34 pm
You can probably find a shop in your area that will mix factory matched paint.
Most will even premix and load it in an aerosol can for you. So if you're good
with a spray can, check it out. Usually it's less than $20 a can.
Postby DSM_Lara » Mon Feb 21, 2011 2:53 pm
My rears are sprayed by can... I forgot how many coats I did. When I was doing it I was just hoping for the best lol. If not there is always re-sanding.
BTW I think it's awesome that your putting a kit on your gen1 vert...
Also, if you have the full kit put on the black rear center valence for now till everything else gets painted. Makes a difference with Just that on temporally while waiting for the rest of the stuff to be painted.
DSM_Lara
Postby Toy1mzfe » Mon Feb 21, 2011 8:33 pm
Hows my front lip look? its dwp. rattle can status.
Postby Dr.Jenkins » Wed Feb 23, 2011 7:34 am
Thanks guys!
Dr.Jenkins
Postby solara_2crave » Thu Feb 24, 2011 6:33 pm
where do you guys get the straight bar grille cause i cant find one...
solara_2crave
Postby Jabraltar » Wed Mar 16, 2011 9:54 pm
I second that ^^^^
Jabraltar
Postby hskrsolara » Fri Mar 18, 2011 12:31 am
Toy1mzfe wrote:Hows my front lip look? its dwp. rattle can status.
up close, im sure anyone can tell its not perfect. in a pic, nobody can tell if its perfect. its all about how comfortable you as the owner are with the end result. me, personally, i'll let the paint shop do a 3 stage DWP so it matches perfectly. DWP is not black, it is a complex 3 stage paint with a pearl finish. it's not easy to duplicate if you don't know what you're doing.
hskrsolara
