SolaraGuy.com • View topic - anotherrr "will it fit" topic...
Postby dinoxor » Tue Apr 26, 2011 1:31 pm
So I've been searching and searching and was not able to find my answer...
3 questions:
1) will a 17x9 +35 wheel fit ><
I don't think it will but was hoping if I were to stretch my tireesss lets sayy 205/40/17 will make it fit with just a rolled fender.
2) if not would 18x7.5 +38 will fit just fine right?
3) and also is there a website I can go to learn about offset, camber, stretching and what not or is this something I need to pick up myself?
dinoxor
Re: anotherrr "will it fit" topic...
Postby ToyoSolV6 » Tue Apr 26, 2011 3:09 pm
17x9 will fit but the +35 offset might kill it because the offset is high and it might rub on your strut, you probably will need spacers to clear it at that point you will drop your offset and the rim will begin to poke a little more, thats when fender rolling maybe pulling and some camber comes into place.
18x7.5 +38 will fit just fine but this one will be tucked in and you will need spacers if you want to be flush.
Postby dinoxor » Sun May 01, 2011 5:02 pm
soo i've been researching and my friend gave me a great deall on thesee wheels!
I think most of you guys have it but the specs are 18x8.5
so I used this website to give me an idea.
http://www.willtheyfit.com/index.php?wi ... mit=Submit
would using 235/40/18 allow my wheels to fit? or would i need to go with 225.
I would like it to give it a slight stretch but not too much since i don't want to spend too much on tires.
as for the offset, it's +35 and i was thinking about getting 15mm spacers
what size would you guys suggest for front and back?
and for the suspensions, I was thinking about getting megans.
tell me whatcha think!
thanks again!
dinoxor
Postby SleeperSolara » Mon May 02, 2011 8:40 am
a +35 will sit flush no need for spacers. i think.
Postby ToyoSolV6 » Mon May 02, 2011 11:06 am
ehh not really, it will be just a tad bit tucked.
Postby dinoxor » Mon May 02, 2011 2:45 pm
lol regardless I would need to roll the fenders right?
dinoxor
Postby SleeperSolara » Mon May 02, 2011 8:55 pm
ToyoSolV6 wrote:ehh not really, it will be just a tad bit tucked.
True, i might have been a tad bit off, lol.
You think +30 would sit flush then ??
dinoxor wrote:lol regardless I would need to roll the fenders right?
Yes.
Postby ToyoSolV6 » Tue May 03, 2011 9:41 am
well a +30 would get closer in this case i would at least say a +25 to be on it. Im on 17x8 and i had +35 and they were pretty tucked now im at +20 and im right on. Put it this way i had to raise the car a sh!t load and now i need camber so i wont rub.
Postby SleeperSolara » Tue May 03, 2011 12:34 pm
ToyoSolV6 wrote:well a +30 would get closer in this case i would at least say a +25 to be on it. Im on 17x8 and i had +35 and they were pretty tucked now im at +20 and im right on. Put it this way i had to raise the car a sh!t load and now i need camber so i wont rub.
I see.
Well i was goin' to go wit a 18 x 8.5, so a +30 should be flush the with out camber??
Dang.
Postby ToyoSolV6 » Tue May 03, 2011 12:37 pm
yeah pretty much you prob wont need camber at that point.
Postby dinoxor » Tue May 03, 2011 1:57 pm
hoorayy mmkay so does a pankcake 5mm spacer sounds good for me?
but without it will I rub on the inside?
dinoxor
Postby SleeperSolara » Tue May 03, 2011 5:01 pm
dinoxor wrote:hoorayy mmkay so does a pankcake 5mm spacer sounds good for me?
What type of rim and offset are you gettin' ??
Postby yaddadaimsayin » Tue May 03, 2011 5:23 pm
this just reminded me of a pickup line:
"can I rub your belly button... from the inside?" :lol:
Postby dinoxor » Tue May 03, 2011 5:50 pm
My friend is selling me his gold xxr 962 18x8.5 +35 so he can get ccw's! ballerrr!
but I just found out that that's napster's old set up. :[
i feel like a biterrr now :[[[
what about you?!
yaddadaimsayin wrote:this just reminded me of a pickup line:
haha random!
dinoxor
Postby SleeperSolara » Tue May 03, 2011 8:38 pm
what about you?!
Cool.
XXR 521 18 x 8.5 + 30 probably.
