SolaraGuy.com • View topic - Headers
Headers
Headers
Postby TheMack » Fri Jun 03, 2011 9:39 pm
hey guys, found out that my OEM headers are cracked so i decided its finally time to upgrade, is this the setup everyone here recommends?
http://cgi.ebay.com/ebaymotors/OBX-SS30 ... 3356898c5d
TheMack
Re: Headers
Postby 1gSE » Fri Jun 03, 2011 9:56 pm
:sweet:
Solara-M62 @ 5.5psi
1gSE
Re: Headers
Postby TheMack » Fri Jun 03, 2011 10:09 pm
very quick question before i hit "buy" this is the 2.5" piping, ive heard the 3.0" is better. Is there any truth to this and if so how much do those cost?
TheMack
Re: Headers
Postby 1gSE » Fri Jun 03, 2011 11:49 pm
That should be the size of the y-pipe after both banks have merged together. I don't think they make a larger version. 3" catback, on the other hand is good for s/c'd and N20, but not for a mostly stock car.
Solara-M62 @ 5.5psi
1gSE
Re: Headers
Postby chullen1 » Sat Jun 04, 2011 6:06 pm
I have nothing but good things to say about the headers themselves, but the y pipe could use some work around the welds. My y pipe broke off right at the weld yesterday and I had to shell out 150 to have the ypipe fixed.
chullen1
Re: Headers
Postby TheMack » Sun Jun 05, 2011 12:10 am
chullen1 wrote:I have nothing but good things to say about the headers themselves, but the y pipe could use some work around the welds. My y pipe broke off right at the weld yesterday and I had to shell out 150 to have the ypipe fixed.
crap, i dont wanna deal with that, how much on an instant power difference did anyone feel stock with only an intake?
TheMack
Re: Headers
Postby SleeperSolara » Sun Jun 05, 2011 12:15 am
Just got mine installed on Sunday and Monday. Took my friend and I about 10 hours, runnin' into issues like a stripped out nut on the bottom left on the front header.
Linein' up the y-pipe and headers is a slight challenge.
Also would recommend on gettin' a high-flow converter, and a O2 simulator also.
That's my plan.
Re: Headers
Postby 1gSE » Sun Jun 05, 2011 12:18 am
if you have a high flow cat, you shouldn't need an o2 sim
Solara-M62 @ 5.5psi
1gSE
Re: Headers
Postby TheMack » Sun Jun 05, 2011 12:34 am
ummmm im stock except for an intake fellas lol
TheMack
Re: Headers
Postby hskrsolara » Sun Jun 05, 2011 12:56 pm
TheMack wrote:ummmm im stock except for an intake fellas lol
not sure where this info got lost, or if a search wasnt done...but here is the low down on headers on the 1mz:
IF you are not boosted (n/a), you will see very little to no gains from headers alone. The oem ones we have are actually a decent design and us guys that have played around with it a bit have not seen big gains from the headers themselves.
The big gains you are seeing are from the high hp guys that are s/c and need the extra exhaust flow. They/we are probably pushing 120-150+ more whp than a stock 1mz. I seriously doubt any n/a 1mz would benefit from aftermarket headers.
One of my best dynos came when I was running the OEM headers, dats y pipe and evo 2 exhaust (supercharged at 5.5psi). The headers are not a restriction in our setup.
The biggest mistake you can make with a n/a exhaust is to go too big. You will lose backpressure and torque will suffer greatly. I would suggest buying a used oem header to replace your cracked one. If you are not boosted, or wont be in the very near future, it would be pointless to go with the full OBX setup.
The biggest gains will come from an updated y pipe. N/A or boosted, this will show big gains. However, on an n/a, be sure to keep the cat back exhaust piping small (~2.25-2.5") or you will lose power.
The OBX y pipe design really isnt that great, imo. I saw bigger gains from my Dats pipe, which was as basic design as it gets. You could prob find one floating around here, or have an exhaust shop make one up for you.
It is a huge PITA to remove and install headers on our solaras/camrys. It is not for the novice and a shop will charge big $$$ to do it for you. This is why I say to only install headers if you are boosted and have high hp goals. On a n/a car, it will be a huge waste of time and $$$. The y pipe and exhaust are easy to switch out. Talk to a local shop about copying a dats y pipe for you and get a 2.25"-2.5" exhaust (or have one custom made at a shop with a muffler you like). That would be much more satisfying than paying $$$ for headers and install that will do nothing to improve your power.
Trying to save you some $. Not all "upgrades" result in better performance. :wink:
hskrsolara
Re: Headers
Postby TheMack » Sun Jun 05, 2011 1:36 pm
damn.....now its got me thinking quite a bit as to what to do....
TheMack
Re: Headers
Postby hskrsolara » Sun Jun 05, 2011 4:54 pm
Which header is cracked? Where is the crack?
hskrsolara
Re: Headers
Postby TheMack » Sun Jun 05, 2011 10:06 pm
i think the middle one because there's an apparent leak around the top of the header and we degreased it, turned on the car, and there was still some smoke coming out
TheMack
Re: Headers
Postby stringbean » Mon Jun 06, 2011 12:29 am
the middle one? please be more specific, maybe try to get some pics if possible.
stringbean
Re: Headers
Postby TheMack » Mon Jun 06, 2011 1:52 am
ill do that first thing in the morning
TheMack
