SolaraGuy.com • View topic - need help with installing HID foglight
Postby wizzy » Sat Jun 04, 2011 3:52 pm
so i just installed 9006 10k hid's for my 2000 solara fog lights but it doesn't want to turn on i flipped the switch a couple of times, turn the car on ect... and nothing seem to work. i threw on the old fog bulbs and turn on the fog lights and they worked perfectly, then i installed the hids fogs on my friends car an impala and it worked fine, i have no idea what might be the problem if someone can help me out that would be great .
i think it might the relay wires idk .
2000 Toyota Solara SE V6
10k Hid Fog's and Headlights
Black Coners
2010 Camry Bars
Basically stock (For Now)
wizzy
Re: need help with installing HID foglight
Postby GzNutz » Sat Jun 04, 2011 4:20 pm
What brand of kit are you using... and have you tried reversing the wires to the ballasts?
Postby wizzy » Sat Jun 04, 2011 4:26 pm
i dont know the brand friend gave em to me, and what do you mean reversing the ballest wires
Black Coners
2010 Camry Bars
wizzy
Postby GzNutz » Sat Jun 04, 2011 4:35 pm
Most kits require you just push the wires from the ballast in to the car's original harness. Having one of the ballast wires switched/ opposite of the other light's can result in them not turning on.
Postby wizzy » Sat Jun 04, 2011 5:38 pm
heres some pics on my installation..
left side is the oem bulb
right side is Hid hooked up
both sides oem and working perfectly
what am i doing wrong lol ...
Black Coners
2010 Camry Bars
wizzy
Postby wizzy » Sat Jun 04, 2011 5:39 pm
if you cant see the right side right click the photo and drag it you should see it in a little drag window .
Black Coners
2010 Camry Bars
wizzy
Postby GzNutz » Sat Jun 04, 2011 5:44 pm
In the first pic, looking at the plug that clips in to the ballast, can you plug it in with the clip facing the light output wire? Twist it 180?
Postby GzNutz » Sat Jun 04, 2011 5:47 pm
And looking at the second pic, the car's white wire is connected to the hid's ballast red. Maybe switch those wires so the red matches with red and white with the black.
Postby wizzy » Sun Jun 05, 2011 11:54 am
thanks man i tryed what you told me to do and it worked perfectly, now the seconced challages is wheere am i going to hide my basslet box
Black Coners
2010 Camry Bars
wizzy
Postby GzNutz » Sun Jun 05, 2011 1:55 pm
Glad to hear you got it working. As for the ballast box, just 3m double sided tape it to the inside of the bumper or frame.
Postby TheMack » Sun Jun 05, 2011 2:06 pm
wrap in electrical tape though
TheMack
