SolaraGuy.com • View topic - will this work?
will this work?
will this work?
Postby parkc96 » Mon Jun 20, 2011 3:07 pm
hey guys will this work on my 2000 camry 4 cylinder?
Megan Racing Toyota Solara (99-02) OE-RS Cat-Back Exhaust System
http://www.hopupracing.com/meratoso9oec.html
2000 camry 4 cylinder: rims, tint, spoiler, head unit, partially debadged, custom catback, custom grille... more to come.
parkc96
Re: will this work?
Postby ToyoSolV6 » Mon Jun 20, 2011 4:27 pm
i think it will i think its for the 2az motor, do you have the 2az or the 5sfe
Re: will this work?
Postby parkc96 » Mon Jun 20, 2011 5:12 pm
i have the 5sfe and everyone says that there is a megan exhaust for it but i cant find it!
parkc96
Re: will this work?
Postby ToyoSolV6 » Mon Jun 20, 2011 7:17 pm
yeah i doubt that exhaust will fit the 5sfe but i could be wrong...
Re: will this work?
Postby 1st Gen Sol » Mon Jun 20, 2011 8:10 pm
OE-RS
http://cgi.ebay.com/ebaymotors/MEGAN-OE ... 177wt_1078
Drift Spec
http://cgi.ebay.com/ebaymotors/MEGAN-DR ... 2774wt_859
That will work on your Camry 5sfe. I would go with the Drift Spec exhaust system however b/c it includes the silencer. The OE-RS exhaust is madd loud and in my opinion very annoying to drive with. I had one for a week and cut off the muffler, replaced with the Drift Spec muffler.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Re: will this work?
Postby parkc96 » Mon Jun 20, 2011 8:49 pm
mine is a 4 cylinder how would that v6 drift spec work? and is it a removable silencer?
parkc96
Re: will this work?
Postby 1st Gen Sol » Mon Jun 20, 2011 9:17 pm
It's a straight bolt on and the hangers are in the same places.
I have both "99 gen.1 Solara's. The 4 banger has a Greddy Evo II (supposidly only for a v6) exhaust and the v6 has the Megan Drift Spec installed. All you have to do is remove 2 bolts that hold the silencer in the canister and it'll slide out......quiet when you need it to be and loud when you want it to be without the silencer.
Hopefully my 2 cents helps you out. Google it on YouTube to hear a sound clip of the exhaust before you buy so you know what your getting before hand.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Re: will this work?
Postby ThatVietGuy » Mon Jun 20, 2011 9:18 pm
IIRC, to get V6 exhausts to work on the I4 you just have to plug the O2 port on the midpipe.
ThatVietGuy
Re: will this work?
Postby 1gSE » Mon Jun 20, 2011 10:47 pm
one thing to keep in mind about the sound clips is the 4cyl and 6cyl will sounds NOTHING alike. You'll mostly find 6cyl solara videos. Most 4cyls should sound pretty similar to each other though
Solara-M62 @ 5.5psi
1gSE
Re: will this work?
Postby parkc96 » Tue Jun 21, 2011 9:08 am
yeah i cant find any videos of it.
parkc96
Re: will this work?
Postby parkc96 » Wed Jun 22, 2011 6:34 pm
how do you plug the o2 port?
parkc96
Re: will this work?
Postby ThatVietGuy » Wed Jun 22, 2011 7:09 pm
I think people just used a big bolt.
ThatVietGuy
Re: will this work?
Postby parkc96 » Wed Jun 22, 2011 8:13 pm
ThatVietGuy wrote:I think people just used a big bolt.
ok?
parkc96
Re: will this work?
Postby 1gSE » Wed Jun 22, 2011 9:10 pm
Solara-M62 @ 5.5psi
1gSE
