SolaraGuy.com • View topic - led and/or electrical help :/
Postby dinoxor » Tue Jul 05, 2011 12:33 pm
so good news I have finally received my leds and bulbs for my car!
bad news, kinda long story....
when trying to change the ignition light,
at first, the led I ordered did not fit, so I tried the bulbs I ordered which worked great when I opened my door.
however I found out that they gave me 2 blue and 1 cool white instead of 2 cool white and 1 blue, when I was exchanging different bulbs into the ignition socket.
bad turned to worst, when I finally decided to just leave the blue bulb for the ignition, I opened the door once more and nothing turned on
so I just ignored the problem and continued to just put everything back together inlcuding the center console I took off.
now when I opened the door my dome, map, and CLOCK lights no longer turns on....
so any solution to this prob? :[
I changed this during the daytime and recently mod the independent fog light if that helps :/
if not I guess I should just give in and drive to the dealership to see what they can do
dinoxor
Re: led and/or electrical help :/
Postby ThatVietGuy » Tue Jul 05, 2011 12:52 pm
Check your fuses?
ThatVietGuy
Postby dinoxor » Tue Jul 05, 2011 1:51 pm
thank you thank you thank you!
dinoxor
Postby St.Anton » Fri Jul 29, 2011 6:47 am
Has it happened to you again? Did it have anything to do with your bulbs?
St.Anton
Postby dinoxor » Fri Jul 29, 2011 10:24 am
Lol yeah it happened randomly one day but havent since afterward. And I think it was because I was changing it out too much trying on different colors
dinoxor
