SolaraGuy.com • View topic - 300 from 3.0
300 from 3.0
300 from 3.0
Postby srkovarik6 » Wed Aug 24, 2011 9:59 pm
Here's my goal: 300 hp from 3.0L. I need some helping figuring out the most efficient ($/hp) way to get there. Here's where I'm starting (I'm only listing mechanical in this post, cosmetics don't mean anything if you can't back them up):
'99 Solara 5S-FE 2.2L, 5-speed, Pearl White - $5000
Custom Borla cat-back dual exhaust +10 hp?
El-cheapo ram air intake
Vogtland lowering springs, KYB GR-2 struts, shocks
TWM short shifter
K&N cone filter
'99 Solara SE 1MZ-FE 3.0L, 5-speed, Black - wrecked, $1000 (computer, motor, tranny are all good)
Here's what I think I need:
Motor/transmission/computer swap (obviously) 190 hp base
TRD Supercharger, 9 psi (duh) +50 horses?
Headers (OBX or the best value you guys can recommend) +15 horses?
Catalytic converter (??) +?
Larger injectors (HKS, Blitz?) +?
Intake (CP-E, Injen? - recommendations?)
Clutch (Competition Clutch Stage 4, 6 pad)
Fuel Management (Apexi?)
Ignition (MagneCor wires + factory?)
Look forward to your recommendations on my journey. I'll post pictures soon and get into cosmetic stuff (wheels, spacers, body, paint, etc.).
Steve
Eugene, OR
srkovarik6
Re: 300 from 3.0
Postby up2thedown » Mon Aug 29, 2011 3:26 pm
u need a supercharger, theres a couple for sale in the for sale section, u need injectors, jims fuel mod, an apexi or a split second fuel managemaent system, an injen intake, new fuel pump, a new clutch, meth injection to be able to run 7psi to achieve 300whp, obx is the best headers & exhaust for the money, u need 3in obx, & a few more things, talk to gregtrd or gabe trd4life & they can hook u up with most everything you'll need...............
up2thedown
Re: 300 from 3.0
Postby ToyoSolV6 » Mon Aug 29, 2011 3:58 pm
^nuff said.
Re: 300 from 3.0
Postby ThurzNite » Mon Aug 29, 2011 4:39 pm
What's your budget?
Dr J
ThurzNite
Re: 300 from 3.0
Postby up2thedown » Mon Aug 29, 2011 4:40 pm
srkovarik6 wrote:Here's my goal: 300 hp from 3.0L. I need some helping figuring out the most efficient ($/hp) way to get there. Here's where I'm starting (I'm only listing mechanical in this post, cosmetics don't mean anything if you can't back them up):
TWM short shifter
K&N cone filter
Steve
Eugene, OR
trd supercharger, 7 lb pully,255 welbro fuel pump, .325 rc injectors,jims fuel mod,injen intake with cold air extension,obx headers & 3" exhaust,no cat,HKS Ing. Amp.,denso plugs,magnacor plug wires,SAFC , GregTRD knock senser mod , jims torque rod, 94.2 octane fuel . poly front motor mount , greg trany mod , 5 speed swap , fadinza flywheel , nst crank pully . & meth water injection, some of the stuff i left out is listed here
up2thedown
Re: 300 from 3.0
Postby Gregtrd » Mon Aug 29, 2011 5:05 pm
The best way to achieve 300whp is to bring it to fontana.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: 300 from 3.0
Postby albertrd » Tue Aug 30, 2011 9:01 pm
:sweet: That's right folks
albertrd
Re: 300 from 3.0
Postby up2thedown » Wed Aug 31, 2011 1:19 am
fontana sucks, been there done that, u want hp give me a holla...........
up2thedown
Re: 300 from 3.0
Postby srkovarik6 » Wed Aug 31, 2011 6:52 am
Wow guys, that's a lot of information. As for budget, I can spend a thousand or two every year until I'm done. I don't intend to drop all the cash right away. This will be a long project. Now another question - with all of these mods to get to 300 hp, will the car still tolerate regular (87 octane) unleaded for regular driving? What kind of fuel mileage would you expect after this kind of modification?
srkovarik6
Re: 300 from 3.0
Postby 1gSE » Wed Aug 31, 2011 7:21 am
you definitely do not want to be running 87 with the amount of work you're looking at
Solara-M62 @ 5.5psi
1gSE
Re: 300 from 3.0
Postby srkovarik6 » Wed Aug 31, 2011 8:52 am
Will the TRD supercharger or an MP90 supercharger run "OK" with 87 octane at all depending on pulley size? Could I run a larger pulley and run lower octane for less boost and switch my belt, pulley, and fuel if I wanted higher horsepower for certain *hypothetical* situations?
srkovarik6
Re: 300 from 3.0
Postby trd4life » Wed Aug 31, 2011 9:02 am
no 91 octane minimum for 4psi. anything over 4psi you will need 93+ octane
Re: 300 from 3.0
Postby crispone » Wed Aug 31, 2011 12:06 pm
Run good gas if you want performance.
Drive a Yaris or Geo or Carolla or some other eco-compact mileage machine if you want to get good mileage and use low octane gas.
Re: 300 from 3.0
Postby srkovarik6 » Wed Aug 31, 2011 12:57 pm
Are you trying to tell me I shouldn't expect 30 MPG and 300 HP with Arco gas?
srkovarik6
Re: 300 from 3.0
Postby chullen1 » Wed Aug 31, 2011 1:45 pm
you can get 30 mpg and 300hp but don't expect your mpg to stay at 30 as soon as you depress you gas pedal.
chullen1
