SolaraGuy.com • View topic - Possible Engine swap?
Postby Vuluz » Mon Oct 17, 2011 9:16 pm
How limited is the solara when it comes to engine swaps?
Wondering if i could fit something more powerful into it such as a chevy v8 smallblock?
Is it possible or no?
Vuluz
Re: Possible Engine swap?
Postby 1gSE » Tue Oct 18, 2011 4:49 am
anythings possible with $$$
Solara-M62 @ 5.5psi
1gSE
Postby ThatVietGuy » Tue Oct 18, 2011 7:44 pm
Just buy a car with a V8 in it.
Unless you want to be the coolest guy in the Lowe's parking lot at the next car meet :rolleyes:
ThatVietGuy
Postby hskrsolara » Tue Oct 18, 2011 10:20 pm
in before the lock...
hskrsolara
Postby Midias » Thu Oct 20, 2011 6:20 am
About the best "easy" swap you can do would be a 1mz 3mz hybrid
But then again 99.99999% of people who ask questions like this never get past a short ram intake but w/e
Postby SpeedySolara » Fri Oct 21, 2011 3:01 am
Midias wrote:About the best "easy" swap you can do would be a 1mz 3mz hybrid
Not that this is fb or anything but I "Like" this comment simply bc it's true!
SpeedySolara
Postby SpeedySolara » Fri Oct 21, 2011 3:02 am
SpeedySolara
Postby chriscarter » Mon Oct 24, 2011 4:24 pm
Have no idea about the details (yet), but I have thought that the V-8 out of a Lexus SC 430 might fit in a Solara with some challenging modifications. Since the V-6 is laid on its side for hood clearance, the V-8 should fit that way too. At least you'd be closer to mating this engine to the Solara trans. Couldn't use the SC trans because the driveshaft comes out the back. There may not be enough body width in the Solara since the SC is north-south power with rear wheel drive and the Solara powertrain runs east-west with front drive. But that would be quite a trick Toyota........almost factory V-8 Solara.
Guess you'd have to find an SC that was totalled from the rear bumper to the back seat! Maybe I'll try it one day if I end up with a buncha money I don't need and a month to play with it.
chriscarter
Postby Vuluz » Mon Oct 24, 2011 10:36 pm
That's actually a pretty good idea, never thought bout a SC engine swap. It'd probably be way easier than a small block.
Vuluz
Postby SpeedySolara » Tue Oct 25, 2011 2:50 am
The deeper we get into this topic, the more irrational its become. Granted, ANYTHING could be done but you gotta pay to play. Your best options are to COMPLETELY build a 1MZ or 3MZ/1MZ hybrid. (approx. $5000+/-). Good luck.
SpeedySolara
Postby 1gSE » Tue Oct 25, 2011 3:55 am
^^ Agreed. I think (dont quote me on this) another possible swap would be a 3SGTE, but I'd only go that route if i had a 5s, since the 2az is fairly easy to turbocharge. I dont know how involved modifying the motor mounts would be, or if its required at all
Solara-M62 @ 5.5psi
1gSE
Postby Vuluz » Tue Oct 25, 2011 4:26 am
Do you know what specs Im looking at getting with the Hybrid swap?
Vuluz
Postby trd4life » Tue Oct 25, 2011 12:56 pm
Anything is possible with money.
Postby parkc96 » Tue Oct 25, 2011 1:30 pm
here is what you do, give gabe $10,000 cash, and your car for... 3 months? he can let you know on that... and he will set you up 8)
2000 camry 4 cylinder: rims, tint, spoiler, head unit, partially debadged, custom catback, custom grille... more to come.
parkc96
Postby Midias » Tue Oct 25, 2011 1:38 pm
I say go for the V8 if you can fit a small block in a CRX you should be able to do it in a solara.
Users browsing this forum: No registered users and 73 guests
