SolaraGuy.com • View topic - SAFC wiring vs SAFCII wiring
Postby SolaraPete » Fri Oct 21, 2011 1:17 pm
Trying to verify if the wiring diagram in the Tutuorials section for the SAFCII will be the same for the SAFC (buttons, no knob). From what i've found, supposedly the only difference is that the SAFCII has a knock wire. Can anyone verify if thats correct??
Thanks in advance guys..
:cheers:
SolaraPete
Re: SAFC wiring vs SAFCII wiring
Postby Akfahad » Fri Oct 21, 2011 5:14 pm
I would say they're pretty much identical. I went from the SAFCII to the Neo and everything was pretty much the same, except they did without the knock wiring. I'd say you'd be alright following the tutorial.
Postby SolaraPete » Mon Oct 24, 2011 8:38 am
Thanks! :sweet: I'll prob install it this weekend and will report back if it works as planned.
SolaraPete
Postby SolaraPete » Thu Apr 19, 2012 6:22 pm
Well 6mos later i finally got around to installing it - and the wiring was exactly the same, minus the 2 knock sensor wires.
Heres a pic of the final result. The ashtray (i use it as a coin holder) is still fully functional, there's plenty of room to run the wire underneath it.
Hopefully this motivates me to put on the new pulley, injectors, plugs & wires, and fuel pump so i can actually USE the SAFC lol!!!
SolaraPete
Postby trd4life » Fri Apr 20, 2012 12:43 pm
badass pete keep it up!
Users browsing this forum: No registered users and 79 guests
