SolaraGuy.com • View topic - wheels to bigg ! help
Postby wizzy » Sat Oct 29, 2011 3:40 pm
so some guy told me ill need spacers for the front of my solara , then he told me i would need clamps to clamp on the rear shocks to lift them or they will scrap dose anyone know what hes trying to explain to me ??
sizee 19x7.5
2000 Toyota Solara SE V6
10k Hid Fog's and Headlights
Black Coners
2010 Camry Bars
Basically stock (For Now)
wizzy
Re: wheels to bigg ! help
Postby 1gSE » Sat Oct 29, 2011 4:35 pm
Some guy also told me my trd supercharger wouldn't fit :roll:
So they're already on the car and you aren't having any issues? Have you driven it? The only thing I can think of is spacers on the rear depending on the wheel offset. You should have plenty of room up front. Clamps on the shocks....wtf? NEVER heard of anything like that. Maybe he meant springs, but I still don't see what that's supposed to accomplish since the only clamps I know of are spring compressors used when changing shocks/struts
Solara-M62 @ 5.5psi
1gSE
Postby wizzy » Sat Oct 29, 2011 9:05 pm
idk i never heard of that also , the front i need thin spacers and im still trying to find out what this guy is trying to tell me ..
Black Coners
2010 Camry Bars
wizzy
Postby SpeedySolara » Sat Oct 29, 2011 9:16 pm
I think you need to stop listening to this guy Wizzy. Change that guy for a Solara guy.
SpeedySolara
Postby TheGreenDutch » Tue Nov 01, 2011 8:44 am
dude the offset of those wheels are rubbing your strut probably. I think they are about 50 or 55. You need a spacer to run those Lexus wheels in the rear. Check out the thread on offset in the tutorial section. I've been there done that. lol
TheGreenDutch
Postby Mr_Krispy1183 » Mon Nov 07, 2011 9:14 pm
You definitely need spacers in the rear. Front seems fine, what's the issue.
Postby 2Gud2BTru » Thu Nov 17, 2011 1:11 pm
^x2 I had 18's on my car. the rear right would hit the strut on certain dips or bumps. So spacers most likely in the rear.
-01' SLE v6 coupe:Traded in. 223k
-06' Accord Coupe 4banger: DD
2Gud2BTru
Postby demo4o1 » Wed Feb 29, 2012 7:31 am
TIME TO BRING THIS THRREAD BACK TO LIFE..
this is an old thread but blah..
those for one are not lexus rims. theyre toyota highlander hybrid rims. 19" to be exact. you WILL need front spacers. i know this for a fact because my friend has a gray solara with them same rims. i have the venzas on my solara and needed fronts as well
99 SE, 20" toyota venza rims. hidheadlights/fogs LED reverse light, plate light, dome, reverse gauge, DTR mod fog light mod, fresh paint
demo4o1
Postby wizzy » Tue Apr 24, 2012 3:41 pm
i would say hub centric ones, on Japanese cars they shake around 70+ MHP .
Black Coners
2010 Camry Bars
wizzy
Postby ToyoSolV6 » Tue Apr 24, 2012 5:15 pm
If the front is not rubbing he doesnt need spacers. The front on our cars always has a lot more room than you have in the rear. I used to rub when i had my 17x7.5 with a +45 offset on the strut. 5 mm spacers handled that. Then the stance movement came in.
For everyone: if you dont want to rub go with a good offset that wont leave your wheel way the hell inside! get something with a lower offset that will give you good clearance on the strut!
Postby wizzy » Tue Apr 24, 2012 8:27 pm
ineeded front spacers cause the wheel was touching the calipers i think i used an 8mm
Black Coners
2010 Camry Bars
wizzy
